View Poll Results: Are you going to run an LSx engine package in your 67-69 F-body ??
Yes 210 39.18%
No 87 16.23%
346-365 46 8.58%
370-396 41 7.65%
408-415 30 5.60%
427-427+ 63 11.75%
NA 5 0.93%
Forced Induction 54 10.07%
Voters: 536. You may not vote on this poll
Old 09-20-2005, 06:18 PM
Damn True's Avatar
Damn True Damn True is offline
Just out of curiosity, what is involved in dropping an LS into a 1st gen?
Is it a huge can of worms?
In the end would it be easier/cheaper (both perhaps) to do something more traditional but with an aftermarket EFI?
Old 09-20-2005, 06:48 PM
LS1NOVA LS1NOVA is offline
Not a F-body, but close enough
Nate
71 Nova. "The Green Machine" April 11' PHR
Old 09-20-2005, 11:50 PM
chicane's Avatar
chicane chicane is offline
No, actually its simple if you have the right stuff. This just happends to be our specialty.......
Things you'll need:
  • Engine
  • Conversion engine mounts
  • Conversion oil pan
  • Headers and exhaust
  • Transmission
  • Transmission install kit to include a cross member, modified hydraulic slave and bracketry
  • Driveshaft - Either shorten what you have or have a custom one built to your specs
  • Computer/electronics - There are quite a few companies making drop in wiring harnesses into non EFI chassis nowadays
  • Fuel system and tank for EFI system
I know I have probably left some things off of the list, but this is these are the main necessities for a swap..... depending on your chassis being a manual or automatic transmission chassis.
If you have a chance to go to SEMA, stop by.... we'll have everything on display. If not, our catalog will be here shortly with a comprehensive laydown on everything about this subject.
I just wish I could leak you guys some pictures.......
Old 09-23-2005, 06:20 PM
crazy3gz crazy3gz is offline
I'll be doing a 408 probably when i get around to the motor and have the money I've been starting to read up a lot. I have the bolting stuff up part down but i'll be looking to buy most of the stuff that needs to be fabbed up. I've seen some of your other posts and am looking forward to seeing what you put out and the prices. I will definetly keep a look out
Old 09-26-2005, 01:41 AM
Damn True's Avatar
Things you'll need:
  • Engine
  • Transmission
Ok, perhaps I ought to have phrased it differently.
When all is said and done. In terms of cost and difficulty would it be easier to achieve a 450-550hp drivetrain with a t56 or TKO by going with an LSx platform or sticking to something more conventional?
Old 09-26-2005, 12:35 PM
chicane's Avatar
450 - 650 with an LSx and a T56 is a near no-brainer. Its a 'piece-o-pie', cuz all the part are already available and making power with an LSx is way too easy for the modifications and moneies spent.
Old 09-26-2005, 01:48 PM
MaxHarvard's Avatar
I wish i had some "monies" lying around to do that... *sigh*
Old 09-27-2005, 10:02 AM
Steve1968LS2's Avatar
<--- LS2 is on the way baby!
Old 09-27-2005, 12:13 PM
Rick@Rick's Hot Rod Shop's Avatar
Rick@Rick's Hot Rod Shop Rick@Rick's Hot Rod Shop is offline
Getting ready to put one together... dont know what i am going to put it into, but it might rent the engine bay of my 68 for a wile.
Old 09-20-2006, 10:51 PM
tyoneal's Avatar
tyoneal tyoneal is offline
Things you'll need:
  • Engine
  • Transmission
Chicane:
What business do you have and how does someone get a catalog?
Anything LS2 oriented, I am interested in.
Looking forward to hearing from you.
tyoneal
