Old 02-12-2009, 05:31 AM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Default Fuel Line set up?
ok, with out making this to complicated. I need some help running my fuel lines. I have a standard 1998 LS1 Set up. I will be using a single line fuel filter like the one below. Do I need a regulator some where or is that the thing that is on my factory fuel rail?
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 02-12-2009, 06:08 AM
xtremelky's Avatar
xtremelky xtremelky is offline
The filter you are using has an internal regulator.
Mike
Old 02-12-2009, 06:12 AM
bigtyme1's Avatar
Thanks Mike, so all I have to do is run my single fuel line to the motor correct?
69 RS Ragtop
[email protected]
Old 02-12-2009, 09:25 AM
brans72 brans72 is offline
she is looking damn good there!!!!
Old 02-13-2009, 05:44 AM
bigtyme1's Avatar
Can I get the line allready made or do I make them myself? Where is the best place to get everything?
69 RS Ragtop
[email protected]
Old 02-13-2009, 06:03 AM
130fe 130fe is offline
Thumbs up
I bought my fuel line from http://www.tubetechweb.com/67-69camarofuellines.html I bought the dual one for my LT1 setup, but this gives you another option. They do alot of work for Street and Performance, their customer service was very good. Very nice product and it fit like a glove.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 02-13-2009, 12:28 PM
bigtyme1's Avatar
Thanks, I'll call them today.
69 RS Ragtop
[email protected]
Old 02-13-2009, 04:54 PM
Denvervet's Avatar
Denvervet Denvervet is offline
Check with an expert but I believe Fuel injected cars use a return fuel line also. Just a heads up
68 camaro, 572, tko
Old 02-13-2009, 05:17 PM
camcojb camcojb is online now
they do, but the late model LS cars usually bypass at the rear off the fuel filter and only have one line going forward to the engine. That's how his car is set up.
Old 02-15-2009, 10:13 AM
Pantera EFI Pantera EFI is offline
Default Fuel & AIR mixed=engine death
When you feed your engine AIR, it should be from the "AIR DOOR"
The AIR should not come from the fuel line.
When air enters the fuel system, the best way to remove it IS to allow the aerated fuel back into the fuel tank to seperate.
Lance
