Old 02-26-2009, 07:56 PM
1969rs's Avatar
1969rs 1969rs is offline
Thanks for the information. I have noticed some run tubular on top and stock bottom. It does look cool, no doubt about it. Is there much difference in the brands?
Old 03-17-2009, 09:19 AM
Hotchkis Hotchkis is offline
senior member
There's a BIG difference between brands. Granted we'd love everybody to run our stuff, but at the very least stick to brands that engineer, TEST and manufacture everything here in the U.S.A. There are several companies out there with parts that look similar to the good stuff in pictures online, but are manufactured in China using inferior material and with zero product testing.
You should also stick with a company that has a muscle car background and thoroughly track tests everything it makes. A part deceoped for a specific muscle car application to solve a problem with improved geometry, rigidity and adjustability will always work better than a part adapted from another application.
Also, beyond the "bling factor" mentioned in the post above, other reasons to use tubular lower control arms include (in our case) delrin bushings that minimize deflection, adjustable ride height thanks to stackable spring cup inserts to fine tune the perfect stance, and the ability to use coil-overs if you want (however we've had fantastic results with sport springs and performance shocks).
Whether you use our stuff or not, do your homework and buy the most effective and reliable domestic parts you can.
Old 03-17-2009, 10:38 AM
VP23271's Avatar
VP23271 VP23271 is offline
Check out Global West. I have a set and I am very happy with the quality.
You will first need to decide if you are going with coilovers -vs- a coil + shock setup. Then do your research on who offers what.
Rick
"Better to Be Lucky than Good "
Old 03-17-2009, 09:21 PM
Blake Foster's Avatar
There are alot of options, for sure.
check them all out and then go for it.
Hotchkis make a few good points
I don't know if they Must be made in the USA, Canada has some good stuff to offer too.
Blake Foster
www.speedtechperformance.com
Old 03-24-2009, 07:22 AM
senior member
Meant no offense to our neighbors from the North. Just meant "NOT" made in China where you have no control over steel quality, weld quality, consistency of geometry, etc.
Old 03-27-2009, 07:42 AM
Heidts#14 Heidts#14 is offline
Well said China =
