Originally Posted by enthusiast
As mentioned, you can get the Baer system with an aluminum hat section. Additionally, there is a reason the Baer brackets weigh more than the Wilwood brackets. There needs to be sufficient struture in the brackets to prevent any flexing in the system. If you get any flex in the brackets or calipers, you will get a long or soft pedal. If you are not pushing your car hard on a road course, why are you so concerned about weight. Safety is he main concern with a brake system.
Do you actually work for Baer or just one of the die hard loyalists? The typical Baer kits are not that impressive and can be easily duplicated for a fraction of the cost. Wilwood brakes offer a true competition upgrade vs. OE design that we just slap our name on and provide a bracket to adapt it to other spindles. Please bring tech if you intend to put down a manufacturer, simply stating that one is better (after admitting you have never used the one are putting down) is in very poor form.
I would add that simply making a bracket heavier has zero to do with strength or structural integrity. The reason for the concern about weight is that in a brake application that is known as un-sprung weight and has the same affect as adding almost 3X as much weight anywhere else on the car. Un-sprung weight leads to suspension unbalance, poor braking distances, poor acceleration, accelerated tire wear, and reduced fuel economy.
Got to add my smiley so nobody takes this the wrong way.
