Old 03-07-2009, 07:45 PM
vannatta20 vannatta20 is offline
Default Ford 9 Inch axle bearing removal
Can the bearings be removed with damaging them? Also can i buy just the bearing retainers if the bearings come off without being damaged?
Old 03-07-2009, 08:30 PM
fabricatordave fabricatordave is offline
from my exp. aaaahhhhh no and no it takes so much force to get retainers off that it will split outer race and send bearings allover the shop you can heat the retainer to get it off but you ruin the bearing seal we usually just cut them off at work because it is the quickest way and bearings are like 40$ each
Old 03-07-2009, 08:52 PM
Dang, I was hoping not to have to spend 90$ on bearings. The bearings are brand new and at the time I did not have the LS1 backing plates so we made our own retainer. I finally tracked down the LS1 plates and need to install them. Does any one know what kind of bearings they are? I think they are Ford small bearings.
Old 03-07-2009, 08:57 PM
try this
http://www.moserengineering.com/Pages/diagram.html
Old 03-09-2009, 09:25 AM
Apogee Apogee is offline
Ford big bearings are 3.150" OD [80mm] and small bearings are 2.835" OD [72mm]. I normally cold chisel the bearing retainer and then press off the bearings.. Sometimes they come relatively easy, sometimes not so much, but I wouldn't reuse them. You should be able to get a pair of small bearings (Timken) for $30-$40 locally...bigs are just a bit more. The SET20 tapered rollers are the spendier ones.
Aren't the center holes on the LS1 backing plates 72mm diameter, same as the Ford small-bearing? If you're using those with a small-bearing rear end, I would think you'd need to run a separate retainer like you've shown in the picture along with a spacer collar to make up for the thickness of the backing plate, .525" or so, plus the counterbore depth of those retainers (unless you just flip them over). If I'm not missing something, you could just bore out the backing plates slightly and slide the axles through them...but then you need to figure out if you can get your retainers in place with the parking brake components in the way. Things get tight quick, but that would save your bearings possibly.
Tobin
KORE3
www.kore3.com
