Old 03-15-2009, 02:17 PM
G_T's Avatar
G_T G_T is offline
Default 70 Dodge Charger - Viper powered. Project "Hiss"
I noticed my threads were scattered all over about the build of my Charger, so I'm going to consolidate here and update in one location. First, some launch point:
My web domain with stories of my Charger: http://v10mopar.com I think you'll enjoy the stories.
My thread on Charger.com - Charger boys seem to like the build: http://www.dodgecharger.com/forum/in...c,30342.0.html
My initial introduction here - Where all my $ problems began cause of y'all https://lateral-g.net/forums/showthread.php4?t=15013
Discussion on Forgeline wheels that Frank helped with: https://lateral-g.net/forums/showthread.php4?t=15014
Fun with Moser 60 / 14" Wilwood mockup: https://lateral-g.net/forums/showthread.php4?t=18171
Thread on Triangulated four-link: https://lateral-g.net/forums/showthread.php4?t=18200
Initial construction of air intakes: https://lateral-g.net/forums/showthread.php4?t=15290
When I acquired my Charger (see my v10mopar domain for more info) it was originally equipped as a stripped down model:
Original Specs:
> 318-2bbl engine ~230 HP
> A904 Automatic transmission -column shift
> 8-1/4” Rear with 2.71:1 ratio
> Four wheel manual drum brakes
> Power steering
> Magnum 500 wheels
> Rally suspension option (basically upgraded T-bars and leafs, anti-sway bar).
> Rear window defroster
> Bench seats
> A/C
> AM Radio
> Plum Crazy Purple
> White vinyl top
> White Interior w/black carpet
Here are the current build specs:
> R/T Clone - badging, side scoops, tail stripe
> Plum Crazy Purple - no vinyl top
> Gen 3 Viper V10 ~550HP
> Tremec Viper Six Speed manual transmission
> Black interior - SRT-10 front seats. Everything else stock.
> OEM Console with Pistol Grip shifter and custom grips.
> Forgeline 18” 3-piece billet Wheels
> Wilwood 14” four wheel disk brakes 6 piston calipers in front, 4 in rear.
> RMS Alterkation Front suspension with power steering 1.25” sway bar, 550 lb coilover QA1 shocks
> Moser 60 narrowed rear, 3.73:1 ratio, Truetrac, 35 spline axles, Aluminum support cover, billet yoke.
> RMS Street-Lynx triangulated 4-link rear suspension 220lb Coilover QA1 shocks
> Frame Connectors, boxed frame rails.
> Torque Boxes front & Back
> XV Motorsports lower radiator and shock tower frame supports.
> Full set of Autometer Sport Comp II gauges.
> Flaming river tilt steering column
> Tons of small modifications to make everything work...
Body mods are minor, essentially removing the vinyl top and the removal of the roof and a-piller rain channels to give it a more modern appearance.
The car will look essentially like the attached pic - except with the Forgelines. Haven't decided if I will do anything special with the paint yet.
1970 Dodge Charger: Viper Gen III V10/6spd, RMS Alterkation, Moser 60, 4x14" Wilwoods, RMS Street-Lynx triangulated four link. Currently mocking up...
Old 03-15-2009, 03:25 PM
joe440's Avatar
joe440 joe440 is offline
badass project, goodluck
Old 01-31-2010, 04:17 PM
GHOSTDANCER GHOSTDANCER is offline
Just got done reading about your accident over on the charger forum. Glad to hear your making a good recovery. How is the progress coming
Old 01-31-2010, 04:44 PM
elitecustombody's Avatar
How is your arm? What's the current state the car is in?
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 02-01-2010, 10:15 AM
G_T's Avatar
G_T G_T is offline
Default Quick Update
Thanks folks... Arm is 100% now. Took about 6 months for full recovery. Project Hiss is currently in storage/hibernation until spring/summer. I did pick up the ISIS multiplexing system for it - i'll be playing with the wiring diagrams and such to keep me occupied (lots of thought goes into it).
One stumbling block/challenge i have is what to do about switches. I have no issue replacing the factory switches, but finding a vendor with quality items that have a "muscle car" look vs "european" is a challenge... any suggestions? With the Isis system, i can pretty much use anything.
The most difficult piece is the dimmer thumb wheel. I really like this arrangement, but can find no decent aftermarket unit... I can find the gm type of rotary knob - but i prefer not to use this... this switch has to match and look like it fits with the rest.
Old 02-12-2010, 12:26 AM
71dusterjon 71dusterjon is offline
this will be a good build. just added a srt10 ram regular cab (paxton supercharged) to my 71 duster.
