Old 03-19-2009, 09:34 AM
Northeast Rod Run's Avatar
Northeast Rod Run Northeast Rod Run is offline
Default Removing Anodizing
I didn't really know where to post this so I figured it would get plenty of traffic in here.
I am trying to remove the anodizing from some AN fittings for polishing, but sanding sucks
I heard about the whole "oven cleaner" thing but I have never tried it. has anyone here actually done this with good results?
Old 03-19-2009, 10:28 AM
rwhite692's Avatar
The oven cleaner will remove the anodizing but may whiten or make "splotchy" patterns in the aluminum. It is very aggressive for this, probably too aggressive.
Eastwoood sells an anodizing removal solution that works very well, leaving the parts clean and bright. I have used it with excellent results.
A more "budget" way to do it would be to soak the part in un-diluted Castrol Super Clean ($5/Gallon at walmart) and check the part frequently. Since you plan to polish the part, this may work well for you.
Rob
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 03-19-2009, 10:56 AM
VP23271's Avatar
VP23271 VP23271 is offline
Musclerodz posted a similar question in the post below.
https://lateral-g.net/forums/show...&highlight=raw
I picked up a Fragloa catalog from Hillco Fasteners and they sell raw AN fittings and also a stripping agent too.
Rick
"Better to Be Lucky than Good "
Old 03-19-2009, 11:45 AM
thanks guys.
I'll probably give the oven cleaner a try. I'm not worried about the finish because I will be prepping and polishing them afterward.
I have seen "polished" ones in the Summit catalog before, but I have a funny feeling that the quality of finish probably isn't quite as good as I'd be looking for
I know that Castol Super Clean is some tough stuff too
Old 03-19-2009, 12:07 PM
Musclerodz's Avatar
Why not buy stainless and polish them? Or you can buy the fittings in clear annodizing
Mike Redpath
Musclerodz & Customz
facebook page
Old 03-19-2009, 02:50 PM
Originally Posted by 1969 SS View Post
thanks guys.
I am not happy with the oven cleaner deal. It turns them grayish by the time it removes all the anodizing, plus leaves partially removed areas in all the threads and tight areas. Next time I will be trying one of the other things out there made specifically for that.
Old 03-19-2009, 09:04 PM
Yeah oven cleaner on aluminum will look like crap.It sinks down in the metal you almost can't get it off.Why not use a belt sander or maybe a grinder?
Old 03-20-2009, 06:16 AM
Cread01 Cread01 is offline
I have never tried it and I am not sure how it would turn out but I have been thinking about sandblasting a couple of my anodized parts. Does this work?
Old 03-20-2009, 08:29 AM
it would work to remove the anodizing, but it seems it would get grit into small areas that you couldn't clean out, like where the fittings swivel.
Old 03-20-2009, 08:43 AM
ironworks's Avatar
Or just send your fittings and parts to your local anodizer to be stripped.
