Old 10-05-2005, 12:00 AM
Blown353 Blown353 is offline
Default Approximate cost to change 3-pc wheel backspace?
I'm thinking about buying a set of CCW Classics for my car. However, I have some plans for the front suspension that may or may not come to fruition; namely going to 3-4" longer A-arms up front to cut down on scrub radius. Unfortunately if I buy wheels for my current setup I'll need to change backspace on the front wheels if/when I build my longer front LCA/UCA's. Anyone know about how much a backspace change might cost?
Thanks.
1969 Chevelle
Old 10-05-2005, 10:57 AM
TravisB TravisB is offline
I know steve(strfyr68) is currnetly having the BS changed on his rear wheels.....they are Kinesis though!
Kenny Davis Hot Rods
Old 10-05-2005, 01:25 PM
I'd like to know his cost on the backspace change too, because I'm down to either Kinesis K18 or the CCW Classics. (Steeeeeeeeve, where arrrrrrrrrreeeeeeee you?)
1969 Chevelle
Old 10-05-2005, 02:29 PM
I don't know how close you are to ordering but Weld and DPengineering are both coming out with three piece wheels in the next two months!
Old 10-05-2005, 02:48 PM
camcojb camcojb is online now
I paid about $450 to change the inner sections on my Fikse wheels (2); this included them doing the swap and re-sealing the wheels. But you'll need to contact CCW for a real quote, they may or may not be similar.
Old 10-05-2005, 11:40 PM
$450 for two wheels isn't as bad as I thought, and since the initial price of the CCW's seem to be about 25%-30% cheaper than the Fikse's I would hope their re-hooping charge might reflect that too.
Guess I need to call CCW for an exact cost.
1969 Chevelle
Old 10-07-2005, 10:56 PM
Took Took is offline
Went through replacing the inner and outer hoops on ONE of my Kinesis rims about 3 years ago. It was $360 before tax/shipping
