Old 03-24-2009, 08:42 PM
7firebird1's Avatar
7firebird1 7firebird1 is offline
I was leaning mor toward about 415hp or so. I really want somthing that makes decent horsepower but at the same time I would like it to be something I could cruise out of state and back (pro-touring style). Thank's for the feedback, Tim.
Old 03-24-2009, 10:19 PM
68FBODY 68FBODY is offline
What # heads, the head number will be on the center exhaust port.
How much do you want to spend?
1968 Firebird Pro-Touring project
1967 Mustang Fastback Pro-Touring project
Old 03-25-2009, 01:30 PM
7firebird1's Avatar
I don't have heads yet. I was gonna go with maybe 670. I have thought about even going with an LS engine, but I love the look of "old muscle" . Tim.
Old 03-25-2009, 07:06 PM
Personally I would keep it with a Pontiac motor. Ok 670 heads have a 72cc chamber with 2.11/1.77 valves and would be great, however are you going to have them ported? Are you going to utilize the stock 400 crank, rods, pistons?
Old 03-29-2009, 10:25 PM
72blackbird 72blackbird is offline
A block without caps is nothing but a PITA and IMO not worth working on, since you cannot just get caps from another 400 and bolt them on- you have to get them milled down and have the main journals align bored/ honed to assure the main journal bore is perfectly straight (pricey machine work usually reserved for fitting 4-bolt caps to 2-bolt blocks).
Earlier blocks also only have 2 motor mount holes on the sides, and you need the later 5-hole block to mount it in a '71 Firebird. I personally would find a later 70-75 no.481988 400 block and start from there.
Geno
Old 03-29-2009, 11:14 PM
jst8a5.0's Avatar
jst8a5.0 jst8a5.0 is offline
Geno is right. Pontiac mills with the caps in place and when they do that those caps fit that motor only. Otherwise it's a crap shoot to see if you can find others to somewhat fit then have the machining done.
And just go and get some edelbrocks unless your 670's have already been done. They may also be too much compression for iron heads and todays pump gas. With the e heads at least they are aluminum and can dissapate that heat so you are safe with those 72 cc chambers. I ran mine for years and wound up at 11.9 at 114 without really tuning it and in a non wieght reduced street car.
Micah Prudhomme
Concept Fabrication, LLC
Shop page:
http://www.facebook.com/ConceptFab2006
Shop channel: https://www.youtube.com/my_videos
Old 03-30-2009, 09:09 PM
7firebird1's Avatar
So do you think I would be better off selling this block to someone who may have a 67 GTO with a cracked block that acn utilize his main caps? I just hate to dispose of something that really in my mind is a piece of history (a GTO engine). I may just buy an LS engine....duno.
