Old 02-22-2009, 08:24 AM
almcbri's Avatar
almcbri almcbri is offline
Looks great! The rendering looks killer too
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 02-22-2009, 09:59 AM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Floor Pan Removal and Prep:
I removed the floor and decided to reuse the existing torque boxes since they still had the original galvanized coating on them. I ended up sanding everything and epoxy sealing before the new pan went in. Before removal, I added some "L" brackets to locate the rear subframe mounts in the floor pan. These not only locate the holes, but it also helps set the height of the pan to the original.
After Primer:
Chris
Old 02-22-2009, 10:04 AM
ItDoRun's Avatar
Floor Pan Installed:
What a nice piece. After installing this thing, I just kicked back and stared at it for a while. I decided to sand and prime the top side before I installed it. The bottom side will be done when the car gets put on the rotisserie. I refuse to lay on my back and work the underside! It was bad enough welding under there.
Chris
Old 03-29-2009, 08:36 PM
ItDoRun's Avatar
It's been several weeks since I made any progress on the car, so after a pep talk with wife earlier this week, she got me motivated to get back out in the shop and get moving again. So after trial fitting the passenger side quarter, outer wheel house, and tail panel about 10 times, I decided to go ahead and weld the tub and outer wheelhouse in the car. I also modified the trunk hinge support brackets and got them fitted and ready to weld. Today, I epoxy primed the entire trunk area and the outer wheel house. Here's a few pictures. Quarter panel and tail panel installation is on the agenda next.
Chris
Old 03-29-2009, 08:53 PM
awr68's Avatar
awr68 awr68 is offline
Nice work Chris!! You are doing a great job for learning as you go!!
Nice and tight seams at the mini-tubs...that right there shows you care and took your time!
Tony
'68 Camaro
Old 03-29-2009, 09:00 PM
ItDoRun's Avatar
Thanks, Anthony.
Chris
Old 03-30-2009, 12:04 AM
jcal87's Avatar
jcal87 jcal87 is offline
looking good Chris Ill be coming home to TX this summer for a month or so I might have to take a trip south to check this thing out
1968 Camaro Blue
1968 Camaro SS (Sold)
Texas A&M Alumni
Old 03-30-2009, 08:21 AM
ItDoRun's Avatar
Come on by. You should have my phone number. If not, let me know when you'll be down and I'll make sure I'm around. I still owe you that Mini Tub DVD. I haven't forgot about you.
Chris
Old 03-30-2009, 10:57 AM
GHOSTDANCER GHOSTDANCER is offline
Great looking job
Old 03-30-2009, 11:24 AM
CodeRed CodeRed is offline
wow you definitely have some big balls to do all that cutting
1968 Pontiac GTO
1989 Chevy Z24 Convertible
2004 Chevy Colorado ZQ8 Crewcab
