Old 05-01-2009, 08:04 AM
awr68's Avatar
awr68 awr68 is offline
Yes his fuel got WAY hot on last years PT...he had to put some turndowns on it to solve the problem. Basically you don't want the heat of the exhaust hitting the fuel tank......
Tony
'68 Camaro
Old 05-01-2009, 10:46 AM
Interesting... never knew that. What were the symptoms causing him to discover that?
We will have to check on how close it all is and keep this in mind.... turndowns were the original plan...
Old 05-01-2009, 10:52 AM
ccracin's Avatar
ccracin ccracin is offline
The car is looking awesome. Just one comment on the exhaust as well. You shouldn't blow that kind of heat at the rear brakes either. You spent money to help dissipate heat and now you're adding it back in. If you want the sound use turn downs. JMO. Get some video up of that monster running.
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 05-01-2009, 11:34 AM
Completely agree on the exhaust. Dump it.
Old 05-01-2009, 12:04 PM
Thanks Chad. I didn't consider that aspect of heat on the brakes. Good point. I think we will change it out. I think it is only tacked up for now.
Video coming very soon!
Todd, you just wanted to say the word "dump"...
Old 05-01-2009, 12:30 PM
he had the mufflers pointing straight back to the tank; no turndowns or turn outs. Since they were mounted in the normal area in front of the rear end you wouldn't think it would be an issue, but on long freeway runs with the hot exhaust pointed straight at the stainless tank it got so hot his fuel pressure and pump were having issues. He added some turndowns on the Tour and it completely eliminated the problem.
Old 05-01-2009, 12:38 PM
Good to know, and a simple fix/preventative measure!
thanks
Old 05-02-2009, 04:06 AM
A couple different ways to finish the exhaust off here... I think I like the straight down version, and maybe trimming the end of the dump as it looks to hang a bit lower than the rest of the exhaust. Thoughts?
Old 05-02-2009, 04:10 AM
Some IC shots... just gotta get the 4.25" oval to 3" round transition figured out.. We have a plan for that.
Old 05-02-2009, 04:11 AM
I think I'm really diggin this look..... "Mad Max" as Jason called it.
