Old 05-11-2009, 11:02 AM
We own both full frame and subframe cars, in convertibles to boot. if the subframe car is reinforced with a roll bar system, it is going to be plenty strong.
If I jack up EmptyNest (subrame) or Project Prodigy (full frame) the door gap will open a tiny bit on EmptyNest, but only a tiny bit. On Prodigy, no opening at all. Prodigy is amazingly stiff.
Is it worth the 1000 hours of extra work.................Hell No!
Frank Serafine
Old 05-11-2009, 11:19 AM
fxstdale fxstdale is offline
when I built mine I was considering the same Idea of a full frame option for my 68. I opted for the AME rear triangulated 4 bar clip which was .120 wall 2x4 rails, subframe conncectors are also .120 2x4 through floor style, with AME gt front clip and I tied it all togeather with a 8 point cage, so its going to be real stiff. I would have went with a full frame from AME if I would have needed floors. I could have bought the front and rear clips with sub frame connectors already welded in but for me the end result was the the same either way.
Old 05-11-2009, 11:24 AM
fleet's Avatar
fleet fleet is online now
Seriously, a 1000 hours?!
Ouch...I had no idea.
Then again, you guys may have lives...
Old 05-11-2009, 11:26 AM
fleet's Avatar
Thanks for the info, I appreciate it.
Old 05-12-2009, 12:28 AM
Originally Posted by WaterCooledNelds View Post
Thanks Skip. I'll take a look.
Originally Posted by monza View Post
TASTE
hey now! be nice!
Old 05-14-2009, 07:23 AM
CraigMorrison's Avatar
CraigMorrison CraigMorrison is offline
1000 hours to install a full frame on unibody car? That would equate to about $65,000-$75,000 extra on a build. Are you sure about this number Frank? I have seen our dealers in the 80-200hr range but not this much. Not trying to call you out, but that number seems excessive.
Edit- Just spoke with Alloway on his latest MaxG build. He has a sheetmetal shop roll the trans tunnel and driveshaft tunnel for him and doing the whole floor is about 100hours or "two weeks". It can take longer depending on how much you get into the firewall. Bobby felt that it was easier to re-floor a car than fabbing patch panels to repair a stock floor. Then add 20-40Hrs on building body mounts and brackets to hold the body to frame and you are in the 150hr range.
Art Morrison Ent.
www.artmorrison.com
Old 05-14-2009, 07:50 AM
DOOM's Avatar
DOOM DOOM is offline
Okay Frank , are you in that spray booth without a mask again!!! Just messen with ya!!!
Mario
USCOLLISION
Old 05-14-2009, 08:04 AM
fleet's Avatar
Thanks Craig, that is very helpful info.
Old 05-14-2009, 08:29 AM
comp-spec's Avatar
comp-spec comp-spec is offline
Depending on how fancy you get with the metal work, All said and done 150-200 hrs for Max-G install.Then from there, the sky's limit.
Just my 2cents.
Pete
Competition-Specialties.com
Old 05-14-2009, 10:10 AM
Blake Foster's Avatar
[QUOTE=comp-spec;212351]Depending on how fancy you get with the metal work, All said and done 150-200 hrs for Max-G install.Then from there, the sky's limit.
the biggest issue we see is the seat height!! the seat base ends up being higher in the car due to the exhaust and like pete said how fancy you want to get???
Blake Foster
www.speedtechperformance.com
