Old 06-05-2009, 09:47 PM
elitecustombody's Avatar
OMG! as much as you don't like my comments of constructive criticism,I have to put in my .02c, please take the extra time to remove old crust off the pinchwelds around the windows and clean all the rust,loose dirt and old paint, STOP using that garbage red putty, or atleast use it wha is was made for,not use it a skim coat, it was made for small pin holes and I would never use it on anything else,not to fill scratches or do bodywork with it, don't take it as an insult, I just hate to know that this car will rust in no time, when you can take extra time to do it right
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 06-05-2009, 10:21 PM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
your right, I dont appreciate your "comments" especially considering that you were not there to see every step of the process. I know what Iam doing works and I know there are other techniques other than my own. I understand what works and what doesnt by this point and just because you dont do it that way doesnt mean you need to criticize my work. For your info there was no old paint or loose dirt that you seem to think is there. The car was thoroughly cleaned and like i said before you were not there every step and the pictures i posted are just snapshots of the process, not every step of the way. Also I dont know where you think I used the puddy as a skim coat, but as you can see it was in places to fill pin holes.
Brian Miller
-1972 Nova
-1968 Camaro
-1967 C-10 step side 4x4
-2000 Dodge Dakota
it'll buff out........
Old 06-06-2009, 08:21 AM
GM Muscle's Avatar
well if you didnt really think about it you would just assume you primed over everything but im sure that if your going to take the time to replace the quarters, youre going to take the time to do the rest of the job right. my only recommendation for the future is throw the nitrostain away! get some nice evercoat metal glaze to fill in the pinholes and it will gaurantee a quality job..
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 06-06-2009, 08:26 AM
68protouring454's Avatar
evercoat makes an easy sand polyester filler, it self levels, sand easy with 180-220, and has a hardener so it will shrink very little.
good advice
Jake's Rod Shop
Old 06-06-2009, 08:30 AM
almcbri's Avatar
almcbri almcbri is offline
Brian,
it is looking great! keep the pics coming.
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 06-06-2009, 05:47 PM
70TWO NOVA's Avatar
Originally Posted by almcbri View Post
Brian,
thanks, I appreciate it. The acrylic glazing putty works great, I have been using it for years and have never had a shrinking or cracking issue, nor any rust from under the paint. I do take the time to thoroughly clean everything beforehand. Ill post up some more pics as the progress continues.
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 06-07-2009, 02:31 PM
using it for years? I thought you were a beginner in this? ,Oh,wait, I found your post from few months back
Well i appreciate your criticism, but you have been doing this for 18 years and i have been doing it for like 1 year consistantly if that, so please keep in mind in new at this painting thing.....
Once again, take advice from people who have been doing it alot longer than you and know what works and how well it works ,
also your pictures don't lie, you have bondo feathered on top of crud, that car should have been blasted or atleast the areas that you covered up with filler, I can also bet that the rust holes on the leading edge of the roof were just covered up with filler ,not welded up,
I can't blame you ,cause you're just starting, but don't get all worked up ,when someone with over 20 years of real experience gives you advice or comments on your work.
Judging by pics in other thread, looks like you can colorsand and buff,I give you that ,I'd just hate to see slick paint job go to waste when all the rust and bubbles start coming thru
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 06-07-2009, 09:36 PM
70TWO NOVA's Avatar
like I said Ive been doing it consistantly for about a year. But off and on for at least 4. So yeah using it for years is an accurate statement. Thanks for trying though. I must be doing something right for having at least 8+ months of work scheduled if i wanted it. You must be a real busy guy though with your paint work if you have time to come on here and bash other painters work and teqhniques because they differ from your own. Thanks for the try bud, but i will take advice from macco before Id ask you for any assistance.
get a life....
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 06-07-2009, 10:11 PM
70TWO NOVA's Avatar
once again, the pictures do not show the entire process and for you to pass judgement when you were not there to see what was sanded, welded and cleaned is just plain ludicrous. Come see what i do every step of the way and i would be happy to listen to your criticism, but seeing a few random pics of the progress at different stages and to say i did it wrong is stupid. Also the cars I painted years ago (using the same processes) are still looking just as good to this day with no rust or issues whatsoever. Time does tell and if rust was to form it would have after 3 to 4 years without being consistantly garaged. Like i said before, I know what stupid things not to do like cover rust and crap with filler, I will admit to being an amature but i will not admit to being just plain stupid like you make me out to be.
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 06-07-2009, 02:14 PM
I'll reply with your older post
John510; thanks for the compliments, i really appreciate it. I agree with you 100%, i mean i do ask for criticism, thats why i post my work on here. But i would hope that people understand that im 22 and a beginner at this
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
