Old 06-10-2009, 02:07 AM
T-Type T-Type is offline
Question Clay or Foam?
Hey all. I'm looking at adding some custom pieces to a urethane body kit and need to work off the original kit to make the new additions. Looking for recommendations as to what would be easier to work with....the sculpting clay or foam? Keep in mind i'll need to make the new bits out of fiberglass.
Wondering if the clay would be easier to shape or foam. If I use foam will the resin melt it? Is there a specific name for the clay and where is the best place to get it? If I use the foam, what type should I look for? Closed cell of some sort? Any other tips or tricks would be appreciated as well. Thanks in advance.
Old 06-10-2009, 03:16 AM
ProTouring442's Avatar
I've been making my interior door panels from foam. I'm using the blue insulation foam you can find at Lowe's, but you must use Epoxy resin when you do this as the polyester resin will dissolve the foam.
Shiny Side Up!
Bill
You ever wonder what medieval cook looked at the guts of a pig and thought, "I bet if you washed out that poop tube, you could stuff it with meat and eat it."
Old 06-10-2009, 05:29 AM
Mrfixit Mrfixit is offline
I've used foam for some custom interior parts. To make release simple, after I completed my foam mock-up I covered the whole piece with masking tape because resin will not stick. The fiberglass piece simply popped off and allowed me to reuse my mock-up for multiple pieces.
Good Luck.
Old 06-10-2009, 09:15 AM
elitecustombody's Avatar
foam or clay can get pretty expensive,depending on the size of your project,check out fiberglast.com, you'll find what you need here
http://www.fibreglast.com/showproduc...-Foam-156.html
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 06-12-2009, 01:33 PM
Good Luck.
Did you use the home type foam as well? I'm assuming it would sand pretty easily.....
Thanks for all your help guys. The link is appreciated as well.
Old 06-22-2009, 08:19 AM
If you cover it all with masking tape, you can use anything you want because the tape creates a barrier that the resin cannot penetrate. I used simple Styrofoam that I got from a craft store. The shape I was going for was pretty simple so it was quick and convenient. If your going for a more complex shape, you'd be better off buying better foam.
