Old 06-26-2009, 12:12 PM
rallye455 rallye455 is offline
Default ? About using Dynamat on interior roof
When installing dynamat on the interior roof, should the factory insulation be removed first or do you just over top of it? Car is a 72 442 if it matters
Old 06-26-2009, 12:20 PM
Josh69 Josh69 is offline
You'd be best off removing it. It's essentially cardboard/fiberboard. Even though the dynamat may stick, it may not last long and that would suck to have it all fall down onto a new headliner.
The job is a total PITA, but with patience you can do it. I just sat in there for a couple of evenings with a paint scraper and went to town.
1969 Firebird, Black w/Parchment Arizen interior, 383 Pontiac Stroker (350/428 crank), TKO600, Moser 12 bolt, 18" TTII's, Hotchkis, GW, DSE, Speed Tech, Vintage A/C, etc.
Old 06-26-2009, 03:07 PM
redfire69's Avatar
X2. And I remember reading somewhere the product is more effective if applied directly to the metal for some reason.
Ron
69 Camaro Redfire
Old 06-26-2009, 03:28 PM
Thats what I figured...I just got finished...tried scraping with no luck used a 4.5 angle grinder and a wire wheel, made a huge mess but....still have to wipe it down and apply the Dynamat. thanks guys....
Old 06-27-2009, 10:02 PM
T-Type T-Type is offline
applied directly to metal is best. make sure metal is clean and use degreaser as well. when applying use a heat gun to further activate the glue. also another tip....after done applying....seal the edges with silicone and it'll last forever.
