Old 06-30-2009, 08:05 PM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
Still happy that I got to work on this one,Also one of the nastiest sounding cars out there
TRACY WEAVER
www.recoveryroominteriors.com
Old 06-30-2009, 08:32 PM
86Cutlass383SR 86Cutlass383SR is offline
I saw this car at GoodGuys Indy. Pictures CAN NOT do this car justice! So many mods to this car, you could stare at it for hours any still not catch them all.
Awesome car!
Doug Gulley
86 Cutlass Supreme, 383 needing a rebuild, AFR 190, Accel SuperRam, 30# SVO inj, 58mm tb, AFPR, Comp Pro Magnum 1.5's, Comp Cams 280 XFI hyd. roller (230* 236* .576" .570" 113*) Tremec Aftermarket T56, C5 brakes, Rondell 58 17 x 8.5 wheels, *under construction*
I can explain it to you, but, I can't understand it for you
Old 07-06-2009, 10:08 PM
notorious1970's Avatar
notorious1970 notorious1970 is offline
Thanks guys for the comments. I was out at indy with my brothers and talked to a lot of people out there about it. We finally took delivery of the car and are running the supercharger belt at all times and loving it!! You should see a 50+ mph pull in this thing... one word NASTY!
Look for it in popular hotrodding september issue. If your in the chicago burbs and hit any of the local shows, chances are you will see it.
-derek
HOME!
RadRides '70 Nova Notorious
Build thread
https://lateral-g.net/forums/showthread.php4?t=8840
Old 07-06-2009, 10:15 PM
Small Burnout
Build thread
Old 07-07-2009, 01:40 PM
fleetus macmullitz's Avatar
Wow...the more we see and hear of this car the better.
What's the minimum level of motor needed to utilize a F2?
Old 07-07-2009, 04:47 PM
69496 69496 is offline
I know I could find it somewhere but does anyone recall the rear tire size?
Old 07-07-2009, 07:14 PM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Default Rear Tire
295/45/18... works GREAT on the car IMHO!!!
I like a little more sidewall on a muscle car...
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 07-08-2009, 10:38 AM
I agree. I have been trying to find a tire size that I like and that just looks perfect.
Old 07-08-2009, 10:48 AM
Ok I am looking for this tire and can't find it. Is it the T/A kdw. That's what I see on the sidewall but when I look it up the tread doesn't match and I don't see the 295/45/18 size. Can somebody help me?!!
Old 07-08-2009, 12:01 PM
AALynch AALynch is offline
If I recall correctly, the fronts are KDW's but the rears are a tire that's been discontinued for awhile now...
