Old 08-04-2009, 09:24 AM
Ron Fox's Avatar
Ron Fox Ron Fox is offline
[QUOTE=GM Muscle;226838]first and foremost you want a straight, flat canvas. body work and prep are going to be the key to straight car then the paint comes. if you think about it logically, think about a million tiny balls of paint. as you spray, you are "stacking" these particles across the panel. since you have reducer and they are liquid they will melt into each other but not completely they still dont lay out 100% flat. layer after layer will build up and while it may look flat youve actually created a very mellow ripple.
Great example GM. I have never painted a car but that puts a visual perspective on the process. Hopefully I will be able to help out on my car when it comes time to prep the body for paint. (I have put in many hours helping in the area's I am capable with like cleaning, cabinet media blasting, etc.) I hang out at the shop watching and trying to learn all that I can.
Ron
1969 Firebird, 4-speed Coupe
Old 08-04-2009, 02:00 PM
GM Muscle's Avatar
once you get the car ready for paint, id clean it as best you can a few times over.. its nice to get in all the knooks and crannies with an air blower and a tack cloth. then tape her up tighter than dick's hatband. i usually backtape every hole with 2" then stretch the paper as tight as i can and trim it out with my pocket knife(razor would be better) the less paper you have flapping, the better. the paint will dry on the paper and when you shake it on the next coat with the air coming out of the gun. it could come off in your paint causing "trash". also try to avoid and folds in the paper and if you do have them, tape them shut. the paint will float around in those pockets and dry up.. then on your next coat you blow them out of the pocket and they end up causing more trash. also dont forget that 75% of the trash in a paint job comes from the painter himself. cloth and dust off your clothes, hair, etc. a paint suit isnt only for personal protection. using the right reducer will help reduce trash and nibs but all theses little precautionary steps really add up.
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 08-05-2009, 09:50 AM
Ron Fox's Avatar
How many coats of paint does a car get or need. The thinner the coat the better, right?
I did not think about the paint coming off the paper.
Thanks,
Ron
Old 08-05-2009, 11:34 AM
GM Muscle's Avatar
it all depends on the color, paint line, painter, etc. i use ppg deltron and usually 4 coats. just mix it and spray it like the p sheet says.
Old 08-06-2009, 10:01 AM
Ron Fox's Avatar
But in general is thinner paint better than thicker paint when it is applied to the car?
Old 08-06-2009, 01:48 PM
GM Muscle's Avatar
it would be better to do 4 medium to light coats than to do 2 heavy coats if thats what you are asking..
Old 08-06-2009, 01:52 PM
Ron Fox's Avatar
Yes, thanks GM.
Ron
