Old 08-08-2009, 09:32 PM
brans72 brans72 is offline
Default Wiring guru needed AAW hwy 22 and power windows
I was wondering if anyone here could tell me the best way to wire up my factory power windows to a AAW Hwy 22 fuse box? I understand I might have to cut factory harness. Thanks in advance Brandon
Old 08-09-2009, 12:22 PM
think I am just going to cut factory ends off and run them into fuse box unless I can find a end to fit factory plug and run a wire off it like a pig tail.
Old 08-09-2009, 02:00 PM
Gordz32's Avatar
Gordz32 Gordz32 is offline
I think the window switch just needs a power and a ground and the switch itself reverses the polarity to the motor. so you should be fine just running you power window hot wires to the fuse panel. You can cut the terminals off your factory harness and reuse them but I'd suggest taking the terminal apart and soldering your new wires to the terminals in the socket and then reinstalling them. Usually a tiny flat blade screwdriver will work.
67' El Camino: 468BBC, TH400, Grocery Getter
Old 08-13-2009, 10:48 AM
69x22's Avatar
69x22 69x22 is offline
Default power windows
I would hook a relay into the main power supply wire, that way you will not be pulling all of those amps through the fuse panel.
