Old 08-10-2009, 02:59 PM
rogue rogue is offline
Default Those of you with 12:1 Quick Ratio Steering...
I am installing a Lee Manufacturing quick ratio box and was wondering if you guys were happy with the 12:1 box. If you had to do it again would you go 10:1?
Tom Lee is recommending the 10:1 ratio due to the amount of time I spend on the race track but I am concerned it may be too quick....
Old 08-10-2009, 04:39 PM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
I have one and love it. I do alot of street driving and its great.
Brian Miller
-1972 Nova
-1968 Camaro
-1967 C-10 step side 4x4
-2000 Dodge Dakota
it'll buff out........
Old 08-11-2009, 11:48 AM
David Pozzi's Avatar
Haven't heard of a 10 to 1 box, but the 12.7 to 1 is plenty fast if you have the long pitman arm and short outer steering arms. Your lock to lock turns will be about 2 turns. I know if steering boost fails with a 12.7 box it will be very hard to steer the car. Next to impossible if it's sitting still with engine off. If you have a hydroboost system, get the better pump shaft he sells. Shaft breakage with hydroboost will fail the brakes and steering at the same time! It's happened.
David
http://www.PozziRacing.com
Old 08-11-2009, 12:51 PM
David
Thanks for the info and heads up David. I'll give him a holler and mention the better pump. I did tell him I plan to eventually go hydroboost so...
Look forward to meeting you and Mary one of these days out at the track
Old 08-11-2009, 12:58 PM
JKnight JKnight is offline
I have his 12.7:1 box and I'd say that it is plenty quick. I was shocked when I went from my manual steering to the short ratio power steering, definitely have to retrain your brain for how quickly it turns. I think it would be plenty quick for track use, but I have yet to try that myself. Oh, and I have the long steering arms so it's actually not as quick as it could be.
Old 08-11-2009, 01:46 PM
skatinjay27's Avatar
i would think since you do drive it on the streets and the freeway 10:1 is gonna be way to quick... hell if you sneeze while going 70+ you'll fly across 3-4 lanes LOL
AJ
