Old 08-11-2009, 12:51 PM
rogue rogue is offline
Originally Posted by David Pozzi View Post
Haven't heard of a 10 to 1 box, but the 12.7 to 1 is plenty fast if you have the long pitman arm and short outer steering arms. Your lock to lock turns will be about 2 turns. I know if steering boost fails with a 12.7 box it will be very hard to steer the car. Next to impossible if it's sitting still with engine off. If you have a hydroboost system, get the better pump shaft he sells. Shaft breakage with hydroboost will fail the brakes and steering at the same time! It's happened.
David
Thanks for the info and heads up David. I'll give him a holler and mention the better pump. I did tell him I plan to eventually go hydroboost so...
Look forward to meeting you and Mary one of these days out at the track
Old 08-11-2009, 12:58 PM
JKnight JKnight is offline
I have his 12.7:1 box and I'd say that it is plenty quick. I was shocked when I went from my manual steering to the short ratio power steering, definitely have to retrain your brain for how quickly it turns. I think it would be plenty quick for track use, but I have yet to try that myself. Oh, and I have the long steering arms so it's actually not as quick as it could be.
Old 08-11-2009, 01:46 PM
skatinjay27's Avatar
i would think since you do drive it on the streets and the freeway 10:1 is gonna be way to quick... hell if you sneeze while going 70+ you'll fly across 3-4 lanes LOL
AJ
Old 08-14-2009, 09:00 AM
deuce_454's Avatar
10:1 will be like a porsche carerra RSR.. and people would routinely put them in the ditch or spin them on the highway if they got flustered avoiding slower cars... but if you have plenty of track experience it shouldnt be a roblem.. i have a 12:1 on my malibu and often wish for a faster ratio box... just be sure your pump is up for the task... you will be moving large quantities of oil at high pressure... so you will need a race spec pump as well.... or at the very least a matched flow controll valve..
Jake: Hit it.
