Old 08-13-2009, 02:39 PM
mrr1999's Avatar
mrr1999 mrr1999 is offline
The timing cover has a bunch of bolts and a separate timing tab. Gen IV it is. I'll double check the #'s too. Thanks, again.
Mike - Las Vegas, NV
69 Camaro - in process
70 Chevelle SS396
69 Mach I
Yes...Chevys and Fords
Old 08-13-2009, 03:45 PM
70rs's Avatar
70rs 70rs is offline
There also may be a casting at the back of the block inside the bolt pattern where the transmission mounts. It should have the year it was made cast in. An example would be "77 hi perf pass" or something similar.
