Old 11-01-2005, 08:46 AM
syborg tt's Avatar
A Close Up of the new Hi Temp Silicone Connections
There's a Bed Cover - Wait till you see the Custom Material
New Home for the Battery
See I told you the String would work
[/CENTER]
marty-mj
Old 11-02-2005, 12:05 PM
syborg tt's Avatar
Finally last weeks Update 10-27-05
Need to keep the wastegate quiet
The engine bay is starting to fill up
Side Shot of the Downpipe
Drivers Side View
marty-mj
Old 11-02-2005, 12:07 PM
syborg tt's Avatar
Blow Off Valve & a plug for Hi Temp Silicone
Wastage's - Yep there in perfect alignment with the other accessories
The Throttle cable is going back into the firewall
marty-mj
Old 11-02-2005, 12:08 PM
syborg tt's Avatar
The full Monte - Well Almost
And the most important Part "the Brakes" are on and look Awesome
Thanks Laramie
marty-mj
Old 11-14-2005, 09:19 PM
syborg tt's Avatar
The engine bay is actually starting to fill up
marty-mj
Old 11-14-2005, 09:20 PM
syborg tt's Avatar
The Exhaust is almost complete
marty-mj
syborg tt's Avatar
I'm still waiting for one final piece for the exhaust to complete the system.
The Throttle cable has been routed and mounted to the pedal.
marty-mj
Old 11-14-2005, 09:22 PM
syborg tt's Avatar
The new Beltech Swar - this solved some of my clearence problems
Trans Cooler is mounted and resting in it's new Home
I hope this is the final / final time we get to play with this really cool tool. It has been awesome to have while we are waiting for the wheels. With this tool we can turn the wheel thru it's range and see what are clearence issue's my be.
That's it for this week
marty-mj
Old 11-24-2005, 08:24 PM
syborg tt's Avatar
11-19-05 Update
Well not much to talk about this week. I had to special order some parts so we were in a holding pattern.
Here's the new flanges for the mufflers. Just in case i want to pull the muffler off.
And that special order part - the new exhaust tip that will exit out the side of the truck
side view
Here's a great picture of the stock frame to the tube frame transition. Rick "Opie" Waller had a lot to do with the look of this transition. I think his idea worked well.
marty-mj
Old 11-25-2005, 08:11 AM
black2002ls black2002ls is offline
I havn't really been in the forum since this was originally posted...but that is gonna be one SICK truck. I need to go back and look through the whole thread. I don't have the time right now. But I'm sure when I get to it I will have plenty of questions. I'm working on an 02. It is my daily, but I do a little here and there.
