Old 09-08-2009, 05:25 AM
brans72 brans72 is offline
I agree with the air saw ( use it alot lately) the shears are ok but like stated use huge amount of air,only good on mostly flat metal, and got keep the oiled to cut worth a darn. I used a set to take part of my 1/4's off but air saw was the saver of the day. just my .02
Old 09-08-2009, 06:10 AM
ccracin's Avatar
ccracin ccracin is offline
I agree with the air saw and alot of blades!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 09-08-2009, 06:48 AM
kttrucks's Avatar
kttrucks kttrucks is offline
air saw with a small metal blade...... this works great and if you dont force it you can get a very precise cut. Use tape as a guide, and you can start your cut with a rotary saw, or cutoff wheel, then take over with the reciprocating air saw. make sure you're wearing good safety glasses, even though it doesnt make sparts the metal chips get thrown in random directions and will find a way into your eyes..... no fun at all.
When you get to support bracing, break out the sawsall.... its a MF-er, but will go through reinforcements like butter!
KT.
PTFB, Viking, Holley Performance Products, BFGoodrich, Heatshield Products, Turbonetics, Hellion Turbo Systems,TCI, Dennys driveshafts, Eastwood, Preferredline Media, Summit Racing, Strange Engineering, Forgeline, TMI Products, DBR High Performance, Spectre Performance, Vintage Air, NPD, Digitails, Redline Lumtronix, Dakota Digital, Newport Engineering, Stage 8 fasteners, Industrial Depot, Brian Finch, Grant Salter, and many more Good friends with big hearts.
Old 09-08-2009, 02:09 PM
clay69camaro's Avatar
clay69camaro clay69camaro is offline
how clean and easy to use is the cut off wheel. I don't mind sparks but I've been using a mikita grinder with a cutting blade to do all my cuts, and it's messy.
thanks for everyone's inputs too
Old 09-08-2009, 02:58 PM
elitecustombody's Avatar
not hard at all, especially if you have a steady hand, I use my MAC cut-off tool with swivel head, which helps to get in hard to reach places
http://www.mactools.com/product/tabi...334-at35a.aspx
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 09-08-2009, 06:03 PM
I'm gonna go buy one of those right now. I'm tired of working on my firewall and need a little break.
What other tool should I need to buy once I have something welded and I need to smooth it out?
Old 09-08-2009, 06:52 PM
Grinder and angle die grinder with tons of the green sanding dics and multi others.
