Old 09-12-2009, 10:04 PM
6D9 6D9 is offline
Would this unit work for a blow thru set up?? I know you can make TONS of power with a 750cfm carb on blow thru so I would guess as long as you had enough fuel the air flow would be fine??
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
Old 09-13-2009, 08:23 AM
probably not. You'll be limited by injector size; if it can only support 650 hp naturally aspirated it'd support even less as forced induction due to the richer a/f required for forced induction.
Old 09-13-2009, 09:13 AM
Steve1968LS2's Avatar
Not only that, but I don't think it support it in terms of air. In our tests we ran out of air before we ran out of fuel.
Old 09-13-2009, 11:13 AM
yeah, that's more of an issue n/a, with forced induction you'd run out of fuel way before the airflow was an issue.
Old 09-18-2009, 08:02 PM
6D9 6D9 is offline
Thanks Jody!
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
Old 09-30-2009, 11:42 AM
johnny5's Avatar
johnny5 johnny5 is offline
Can this system be used with an rpm air gap? I see single plane used with all the efi set ups
Old 09-30-2009, 12:18 PM
ccracin's Avatar
ccracin ccracin is offline
Any 4150 style intake. In other words square bore 4-bbl intake. Hope that helps.
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 11-05-2009, 09:32 PM
Steve88 Steve88 is offline
I have the EZ EFI set up on the LS1 in my 67 Firebird and I like it. I love the way the Vic jr's look on the LS1's so I was able to get that look and still have EFI so it was a win/win for me!
Old 11-23-2009, 08:07 AM
Pantera EFI Pantera EFI is offline
Default Winston Cup Cars
This may be the system that NASCAR will use in 2011.
Will there be some refinements ?
I hope so !
Old 11-26-2009, 09:40 AM
protour73 protour73 is offline
still not clear on whether or not this system needs a proper FI fuel tank with an onboard fuel pump. The way they SELL it on their website, it doesn't seem like you do, but from all that I have read, sounds like a must. That pretty much takes away from a "bolt on" selling point........even though a fuel tank does "bolt on".
