Old 09-13-2009, 01:42 PM
Very nice.
Jake did you remove the pinch weld on the rockers?
Old 09-13-2009, 01:44 PM
GrnDragon's Avatar
GrnDragon GrnDragon is offline
That looks great!!!
I am in the saving mode for my Max G, what ride height is that frame set up for?
[SIGPIC][/SIGPIC]
-95 TA Lime Green/Charcoal (Work In Progress)
http://www.cardomain.com/ride/214636...tiac-trans-am/
-69 Camaro Hardtop (Full Frame Project)
http://www.cardomain.com/ride/384710...vrolet-camaro/
Old 09-13-2009, 01:46 PM
68protouring454's Avatar
a few more
Jake's Rod Shop
Old 09-13-2009, 01:56 PM
yes, we cut the inner rocker completely out to the upper pinch weld, which is about 1 inch beyond the lower pinch weld, then plated across the rocker with .188 4 inch flat stock, using plug weld on top and solid welding rocker to bottom edge of flat stock, then metal finished to 180 grit. the frame is a 5 inch rocker height, bottom frame height set up.
Jake's Rod Shop
Old 09-13-2009, 02:07 PM
Thanks Jake.
What kind of ride height?
Are you going to tie it with a cage?
This is going to be a killer project. Please post more pics
Old 09-13-2009, 02:10 PM
yes, car will have a nicely tucked 10-12 point cage, 1.75x.120 dom.
ride height will be 5 inches at rocker, need to make it drivable.
Jake's Rod Shop
Old 09-13-2009, 02:11 PM
tmadden's Avatar
tmadden tmadden is offline
Default Firewall
Is that a pre fabbed firewall or something you made? If so where to purchase?
Old 09-13-2009, 02:26 PM
We made it. i have a template and can make one pretty easy., it can be with or without the wiper motor opening.
Jake's Rod Shop
Old 09-13-2009, 02:37 PM
Bakaruda's Avatar
Bakaruda Bakaruda is offline
Nice ride.
Old 09-13-2009, 03:49 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Looking good. Love the smoothed firewall.
