Old 09-27-2009, 04:10 PM
cwylie cwylie is offline
Default Sagging Chassis?
So recently bought a pro street 68 Camaro I am looking to turn into more of a modern pro street car. Durring the process of making the door bars removable I took the interior out. I saw I wrinkle on the tranny tunnel then realized the drivers door was stuck out a little at the bottom. Well looking further the passenger is as well and the door gap is a little tighter at the top than the bottom. The doors close fine though. Could the car be sagging in the middle? I find that a little hard to believe since it has a 12 point cage? Could it be from a wheel stand that he came down too hard on?
Old 09-27-2009, 04:15 PM
Every Camaro has a wrinkle near the firewall if that's what you are concerned with.
Old 09-27-2009, 04:37 PM
No this one is right between the 2 seat belt bolts on the tunnel.
Old 09-27-2009, 05:34 PM
ccracin's Avatar
ccracin ccracin is offline
It can have a sag with a 12 point cage if it was installed after it sagged. Some folks get crazy cutting a car up before it is properly braced. If it wasn't caught and the cage was welded in then you have a permanent sag. Just a thought! Good Luck.
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 09-27-2009, 07:12 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
They all have that wrinkle in them. My original floor had it and the new reproduction full floor had it. See the picture below. Is that the same wrinkle you're talking about?
Chris
Old 09-27-2009, 07:19 PM
skatinjay27's Avatar
also the door gap issue is probabaly just the door hinges are warn(hole wallowed our where pin sits)
AJ
Old 09-28-2009, 05:37 AM
That does look to be in about the same place as mine. I will get a picture and post it up?
