Old 10-02-2009, 07:01 AM
Silver69Camaro Silver69Camaro is offline
There are no substantial weight advantages to any subframe swap.
Well, swapping to an aftermarket subframe (with 14" brakes) can drop 50-75lbs compared to a stock subframe with power steering and discs.
Matt Jones
Mechanical Engineer
Art Morrison Enterprises
Old 10-04-2009, 04:00 PM
Rhino Rhino is offline
Originally Posted by Sundance View Post
A bare, no A-arms or engine mounts sub frame is no were near 261 lbs. Either that or the time at the gym has paid off...
Maybe 150-170. I pick mine up and move it around by myself all the time, it's more awkward (balance) then heavy.
I would agree. I'm 140 lbs dripping wet, and I was able to move it around the shop myself.
It's bulky, but not nearly as heavy as it looks.
Old 10-04-2009, 04:56 PM
almcbri's Avatar
almcbri almcbri is offline
I was aware that he asked for a bare frame, but If you check out the link of information I posted you can see 261 lbs. with arms and all in the picture. Getting rid of the box, sway bar, spindles, coils, arms, hubs, and crossmember can easily drop 100-110 lbs.
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
