Old 10-21-2009, 05:38 AM
av8or32 av8or32 is offline
Default Seam seal post-epoxy?
I've just finished epoxy coating my floorboards and I was wondering if I should seam seal before laying down the sound deadener. The car had some sort of sealer previously (black tar-like substance) but do I really need this after three coats of epoxy?
Old 10-21-2009, 06:15 AM
J2SpeedandCustom J2SpeedandCustom is offline
It's presonal preference. I like to use Fusor self leveling 123 seam sealer, then any sound deadening material.
Jeff Allen
J2 Speed and Custom
Old 10-21-2009, 07:13 AM
elitecustombody's Avatar
it's a good idea to use seam sealer on joints,unless you like damp and stinky carpet
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 10-21-2009, 12:29 PM
69MyWay's Avatar
69MyWay 69MyWay is offline
What he said...
Plus, here is a tip that will save you money and gives excellent results.
For INTERIOR seam sealing...consider using LIQUID NAILS - right from the good old hardware store.
You can use some mineral spirits to slick it and smooth it...and it will stand up to anything else out there you can get from the auto body store.
I actually picked this tip up from a fellow that does six figure restorations.
He puts masking tape on his finger, dips it in mineral spirits, then uses it to press and flow the material into tight joints.
