Old 10-21-2009, 12:17 AM
Steve1968LS2's Avatar
Originally Posted by Thomo5150 View Post
Thanks Russell I was going to set my front castor at 6.5. Not sure how much difference there is between the Corvette C5 and C6 settings. Is your rack location close to factory spec's to stop any bump steer.
Cheers Tim
On my C6 setup I run about 6.5 degrees of caster, but 7 is a good number too.. it's also going to vary depending on a host of factors. The best way is to try a number, test the car and then adjust until you find the best setting.
I also have 1.5 degrees of negative camber.. but I have sperical bearings so the zero deflection means I always have 1.5 degrees.
With rubber some guys dial in more neg camber to compensate for the deflection.
In regards to bump steer, a quick way to check is to make sure your tie rods are dead parralel to your lower control arms.
Old 10-21-2009, 12:26 AM
Thomo5150 Thomo5150 is offline
Cheers Steve excellent advice, Chassis is now on the Chassis table, time to sit back and wait of my ZO6 C5 rolling chassis. . Coming from Cleveland pick a part. Gus and the guys there offer a good old fashion service.
Cheers Tim
Old 10-21-2009, 01:06 AM
Kendall Burleson Kendall Burleson is offline
I try to reply but you box was full.
Old 10-21-2009, 07:57 AM
cwylie cwylie is offline
I was on my way to the coast last week from Austin and tried to find the shop becuase I wanted to see this truck in person but I had no such luck..
Old 10-21-2009, 08:55 AM
rat_rod_russell's Avatar
rat_rod_russell rat_rod_russell is offline
that's because the shop was hiding behind the weeds and you couldn't see the rest of the cars in the drive. LOL. were in Luling on 183 next to the Propane place. Just look for there truck we're next door and share a parking lot.
-Russell
PT-57
1957 Chevy Truck, 6.0L LS, T56, STS Twin Turbos, C6 Corvette Suspension, CAD Designed Frame by Hot Rod Jim's.
https://lateral-g.net/forums/showthread.php4?t=20292
http://www.nerdrods.com
Old 10-21-2009, 09:47 AM
Fixed it.. I empty it and then it fills back up again.. unlike my bank account..
Old 10-22-2009, 09:38 PM
Sorry guys if I don't pay too much attention to question now I'm a little preoccupied.
-Russell
Update
PT-57
Old 10-22-2009, 10:12 PM
Wow.. good progress.. but will it be ready to run and race in a week? yikes!
I thought we were "under the gun"...
Good luck there...
Old 10-22-2009, 10:44 PM
fleetus macmullitz's Avatar
A very colorful life you seem to be leading Russell.
Congrats on all the progress.
Old 10-22-2009, 11:32 PM
Jr's Avatar
Jr Jr is offline
I like those mufflers
Can't wait to see it run at the optima event.
