Old 11-08-2009, 02:52 PM
bighead bighead is offline
Default Distributor anyone using?
Hi,
Is anyone out there using the MSD Digital E-curve distributor PN 8503. It is for the Ford 289/302. Not really sure the best way to set up the switchs. If anyone is using this please PM me or leave a message here. Thanks
Old 11-15-2009, 01:08 PM
protour73 protour73 is offline
Originally Posted by bighead View Post
Hi,
Here is the perfect answer for anyone who owns one of these distributor, or is thinking about getting one.
I found a guy a while back on another site and finally tracked him down, Randy Harper.....he has a product that you can find on ebay http://cgi.ebay.com/ebaymotors/MSD-E...440849856which which is freaking awesome for owners of the MSD Pro Billet Digital E-Curve distributor. For setting the timing on this particular distributor, there are 2 dial switches that are set inside the unit.... based on what you want your timing to be at. MSD included in their owners manual, 2 horrible graphs that are difficult to understand and very incomplete as for as the needed comprehensive setup info for the E-Curve.
Randy went a hundred steps forward and developed a programmable Excel spreadsheet, in which you merely plug in all of your timing information and you get the correct settings for the 2 dial switches inside the distributor......the cost of $7.99 is rediculously cheap. Randy included specific step by step setup info to be completed before making the final settings on your E-Curve distributor.
I am confidant my engine will be running at it's optimal best after setting up the MSD distributor with the help of Randy's product. THANKS Randy!!
