Old 11-13-2009, 02:23 PM
70rs's Avatar
70rs 70rs is offline
What radiator are you running? I have seen many people using OE electric fans from Lincolns, Taurus, and a few others. It depends on how much room you have. Derale has a dual 13 inch unit that pulls 4000cfm, it's a little over 200 bucks at summit.
For the fuel pump you can use any mechanical pump from Edlebrock, Holley or a stock replacement one. Just be sure it puts out the right GPM and pressure. A regulator with a gauge is always a help just to be sure. No need to go electric for the pump with your set up. But if you wanted to there are lot's to choose from. Holley blue pump, Aeromotive, Carter, Summit has a complete fuel system with a pump (electric), filter, regulator and line for about 240 bucks. Part number SUM-PUMPKIT7A. It includes -6 braided line (20 feet) and AN fittings and clamps. That would be more than enough to feed your engine. Some of the external electric pumps are VERY noisy though. I have not used any of the summit brands so I can't tell you how loud this one is.
