Old 11-14-2009, 10:09 PM
2000 cfm won't cool 600hp. You need over 3000cfm especially with AC. Greg is correct, motors like heat to a point. However, injection and carbs are two different ball games. 180 is perfect with a carb where 210 will make it pissed off.
Old 11-15-2009, 08:22 PM
av8or32 av8or32 is offline
my motor's proabably putting out 300 or so at the flywheel.
Old 11-15-2009, 08:29 PM
I have an old saying I like to use about cooling and stuff like that...
Better to have it, and not need it... than to need it, and not have it.
Can't have too much cooling - that's what the old thermostat takes care of... It only allows enough water flow to maintain the temp... and electric fans are temp controlled - so if they're not needed - they don't turn on...
Nothing worse than being stuck in traffic - hot day - and that ole temp gauge starts the dreaded creep.
