Old 11-21-2009, 09:14 AM
DFRESH's Avatar
DFRESH DFRESH is offline
Hey, I've always been curious about how low you can actually go with the Quadra Link and have it still function the way it should. You said on this car you are "ride height dependent"--does that mean it sitting really low---if so, wondering if I could PM you a couple of questions---
Doug
Old 11-21-2009, 09:41 AM
Noodles Noodles is offline
Doug
Its not that low.If I were too go lower the exhaust wouldn't fit.It sits even with A 18 inch rim.We cut about 1/2 inch of the panhard bracket on the frame side.In the bottom hole of the bracket is where the panhard is installed.The panhard runs level at ride height.If I were to do it over again I would relocate the brackets lower for more clearance.
Old 11-21-2009, 09:46 AM
Doug
I would be happy to try and answer them.
