Old 12-15-2009, 07:49 AM
boynton6spd boynton6spd is offline
Default I picked up a Gen VI 454 marine engine...
Going in a 67 Impala Fastback 700R4.
Self contained radiator...No salt issues!
Stock 330hp, roller cam, forged crank.
ONLY 300 HRS!!!
I want to do a "Mild" rebuild 450-475 hp range...
Any advice would be very, very appreciated...
Old 12-15-2009, 09:21 AM
I have some parts for it including a hot roller cam and oil pan that should fit your chassis.
Old 12-15-2009, 10:05 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
you can easily get that kind of power. Here is a good write up on Mark IV and Gen V and Gen VI rat motor differences.
http://www.chevyhiperformance.com/te...ons/index.html
Old 12-15-2009, 08:22 PM
Default What about the heads????
Great article, thanks for the link!
Can this much power (450-475hp) be made with a new cam, 9.8 to 1 Pistons, Edelbrock RPM airgap Intake and 750 cfm carb?
Looking for pump gas, daily driver reliability, with the stock heads...
I'm a school teacher w/ a laughable budget!!!
Old 12-15-2009, 08:23 PM
Is the cam a streetable cam?
PM sent.
Old 12-15-2009, 09:29 PM
Yep, I sent you the specs by PM. My engine had 9.5-1 compression and Dart Pro1 heads. Here is the chassis dyno.
Old 12-28-2009, 05:16 PM
Default Are the heads on this stock motor capable of a 450-475 hp build?
I think they are oval port but not sure, the intake is still on the motor, is there any way to tell externally?
Thanks in advance...
Old 12-28-2009, 06:39 PM
Pull a valve cover and read the casting number there - just do a quick Google of that number...
Old 12-29-2009, 08:08 PM
Default thanks for the idea greg..
i will tomorrow.
Old 01-19-2010, 07:10 AM
68400BIRD 68400BIRD is offline
Make sure it is not a reverse running motor. To keep a bigger boat going straight they reversed I think the starboard motor on some boats so the props were spinning into each other.
