Old 12-13-2009, 01:51 PM
dlouie87's Avatar
dlouie87 dlouie87 is offline
Default Reflasher/ Tuner for LS1 ECU?
Hey guys,
I was just wondering if you guys know any reflasher/tuners to disable the VATS and all the other ECU stuff to make the car run.
I just got the ls engine all wired up and looking for someone to flash it. I'm located a hour north of sacramento if that is any help.
-Dan
Old 12-13-2009, 02:32 PM
awr68's Avatar
awr68 awr68 is offline
http://www.speartech.com/
Tony
'68 Camaro
Old 12-13-2009, 03:45 PM
dhutton dhutton is offline
www.wait4meperformance.com
Old 12-14-2009, 12:52 AM
dlouie87's Avatar
Are there any more. Speartech is pretty reputable aren't they? What their turn around time?
Old 12-18-2009, 09:34 PM
jamesinark jamesinark is offline
Default tuner/programmer
Have you considered buying HP tuners VCM suite or LSI edit?I know they are pretty high dollar ,but you can also tune a few other cars with the HPtuners program and quickly get at least most of your money.You may also find that you will start to appreciate the fact that if you upgrade anything in the future you don't have to find and pay someone else to do it for you, you can just tweak a few parameters and keep up with any mods you might make in the future.I know I'll be going that route as I will be tuning two cars (mine and my wifes)at the same time and both will be modified at different rates and times and also to different levels of performance.With the HP tuners software you can save different programs like if you want one for a little mileage for a trip or an all out program for race gas if you go that route or anywhere in between.
Old 12-18-2009, 11:07 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
Default Ecu
www.pcmforless.com
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 12-19-2009, 12:36 PM
RetroTuner RetroTuner is offline
Originally Posted by dlouie87 View Post
Hey guys,
-Dan
Hi Dan,
I am visiting from Australia,spending xmas in Roseville.
I have EFI Live and would gladly help you out.I have sent you a PM with my cell..
Cheers
Kyle
Old 12-20-2009, 08:52 PM
Default pcmforless.com for sure
Very good suggestion and one I would have to second.They were very helpful and have many ,many options for many different builds and had more than a few suggestions for my particular setup with HPTuners that will save me a lot of time and more than a few headaches.I believe they can help just about anyone regardless of their needs.I've never seen so many different services for so many different applications.Great suggestion,you should take his advice.
Old 12-20-2009, 10:49 PM
dlouie87's Avatar
I'm just not that talented/knowledgable in tuning... and I dont want to blow anything up....
But thanks for all the inputs. I think I found a guy out of sacramento that gearhead garage recommended me to go to.
