Old 12-30-2009, 10:43 AM
Karl Buchka Karl Buchka is offline
Default C5 Corvette differential measurements
Hey guys,
I just picked up a 6 speed from a wrecked C5 Z06 to use for mockup in the Volvo, but there was no diff included. Before I get a diff I'd like to at least get a general idea of where the transmission will sit in relation to the rear axle centerline.
Would anyone with access to a C5 manual transmission and/or diff be willing to take a couple of rough measurements for me?
I would need the differential's output shaft to output shaft width, as well as the distance from the axle centerline to the diff/trans mating surface. The precision of the measurements is absolutely critical. +- 1/4" is more than adequate.
Thanks!
Karl
'82 Volvo
Old 12-30-2009, 11:19 AM
Differential's output shaft to output shaft width: 14.5 inches
Distance from the axle centerline to the diff/trans mating surface: 4.48 inches
Jim
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 12-30-2009, 01:11 PM
Jim,
That is much appreciated. Thank you!
Karl
'82 Volvo
