Old 01-05-2010, 01:39 PM
Here's my CUTTING TABLE made from the surplus grates:
I made it to fit just under the side door on my blast cabinet - that way I can use it to load or unload on -- and it's on wheels so I can pull it out to use it anywhere in the shop.
Old 01-05-2010, 01:43 PM
youthpastor's Avatar
HMMMM...."CAN I BORROW THAT TOO "
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
Old 01-05-2010, 01:48 PM
This is the welding/work table I made from a 1/2" sheet of steel... I added the "square post" at one end so I could drop some power there - and then later added the "peg board" cantilevered out so I could hang some "stuff" on... it keeps most of the table clear and I haven't run into any interference problems "yet". I use the POST for spools of wire storage and to 'stick' various vise jaw cushions to etc.
I mounted my Beverly shear to one leg ---- and on the other end - mounted my braided steel cutting saw...
Old 01-05-2010, 02:09 PM
Chris (Youthpastor) ----- What's mine is yours buddy!!
Old 01-05-2010, 02:16 PM
Made this "clamp" holder from some square tubing... and it hangs down from the ceiling... I find hanging them overhead --- is easier for me to find the one I want - than when I had them down lower... But what the heck -- I'm old... so what do I know...
Old 01-05-2010, 02:21 PM
BTW -- If you happened to notice the "corrugated" galvanized steel "overhead" -- that was a good use of some left overs. I found that if I put it up (bends easy) between the floor joists... and then put the fluorescent lights up -- it made a great REFLECTOR.... HUGE difference in the 'down light' I got from them!!
Old 01-05-2010, 02:44 PM
I tell you what, that shop looks like it almost gets used.
Old 01-05-2010, 02:53 PM
Table designed with removable/flipable top with levelers.
Grinder Rack on side.
Another good idea is a shelf designed with a grate - to let all the weld trash and shop dust to drop thru.
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 01-05-2010, 02:55 PM
wiedemab's Avatar
wiedemab wiedemab is offline
Default My Monster Bench/Table
Here is my monstrosity of a work bench. Way, way Heavy! - - but I picked up these platens out of an injection molding machine at an auction for super cheap, so what the hell.
Here are the plates
I built it upside down and used the neighbors loader to flip it over - did I say it's Heavy!
We have several things mounted to it and continue to come up with other ways to mount stuff to it. I use the holes in the plates for all sorts of things. I've also drilled and tapped additional holes as needed.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 01-05-2010, 04:30 PM
Nope... just read my signature... that tells you all you need to know!
