Old 01-05-2010, 01:53 PM
Table designed with removable/flipable top with levelers.
Grinder Rack on side.
Another good idea is a shelf designed with a grate - to let all the weld trash and shop dust to drop thru.
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 01-05-2010, 03:32 PM
That's a good looking design - and I like that it rolls...
Old 01-05-2010, 08:22 PM
RomsMotors's Avatar
RomsMotors RomsMotors is offline
Here are a few pictures of my welding table that I built for my shop. The top is 3'x6'x1/2". The table top is about 30" high. The base is made out of 2x2x.250" uprights and the crossmembers is 2"x3"x.250. The top is bolted to the frame for the ease of replacement if it ever gets damaged. I had the frame powder coated. I also added two peices of tubing across the end to hang clamps.
Old 01-05-2010, 08:33 PM
That's a beauty Scott!
Old 01-05-2010, 08:48 PM
RomsMotors's Avatar
Thanks, at first I don't want to use it after I got it done. It look to nice. But I built it to use it. The table has been a handy piece of equipment to have around the shop.
Old 01-05-2010, 09:11 PM
Default Wow !
Very nice Scott !!
Can you tell us who makes the levelers ?
How much over hang is there on the table top - and is that enough in your experience using it ?
Beautiful job !
Old 01-05-2010, 09:21 PM
Jim --
I didn't do any 'under table support' on the front of my table - with the exception of a leg to table top brace... Where as on the sides and all across the back side - I used 3" angle iron welded intermittently to make sure the top stayed flat.
The reason nothing in front - CLAMPING... I wanted a place to be able to use any kind of clamp without under table interference. In the back - I stepped in about 6 inches...
My floor is level - so I didn't have to do levelers of any kind.
Old 01-05-2010, 09:24 PM
General questions for everyone:
Do you prefer to weld setting down or standing up ? I see most of these tables have cross bars on all corners - while a couple designs would allow you to sit down and slide under the table a bit on a stool to get up close to the work.
Some of these are pretty tall too. Bar stools or standing and leaning over ?
Grounding thru the table or directly to the part ? If thru table - are you using the clamp, a stud/stub, or bolted on style of connection ?
Old 01-05-2010, 10:21 PM
RomsMotors's Avatar
Very nice Scott !!
Beautiful job !
I don't know the manufacturer of the levelers. I did order them thru McMaster-Carr out of Chicago. They have 3/4-10 stud with a 2.5" dia. foot. The hang over is 3" for the most part it fine, but I have had some item on the table where I wished it was a larger hang over. I also have drill and tap hole in the surface and used hold down clamps. It’s hard to build a table that will work perfect for every job that you build.
