01-16-2010, 03:08 PM
01-16-2010, 03:14 PM
Looks good Chris!!
What's the old saying - measure twice - cut once...
Looks like you got it right on!
01-16-2010, 03:17 PM
Originally Posted by GregWeld
Looks good Chris!!
I bet I measured that subframe 40 times making sure it was square.
01-16-2010, 03:54 PM
Tony
'68 Camaro
01-16-2010, 03:59 PM
Originally Posted by awr68
I know. I thought about that several times. What would be nice is if someone could make sub frame connectors like the DSE ones that only weld on the bottom side of the car without going through the floor. I don't know if the strength would be there, though.
01-16-2010, 04:07 PM
You had to cut the SFC to length and weld on the close out plate, right? If so....nice welds man!!
Tony
'68 Camaro
01-16-2010, 04:14 PM
Yeah, I had to cut about 1/2" - 5/8" off the end and then weld the end plates on. I've been testing the waters on TIG welding when I'm slow at work. I wanted to TIG the brackets and end plate on these, but I would have to wait until Monday and this part of the project has been dragging on too long. Thanks.
01-16-2010, 04:40 PM
Nice clean welds
Chris I like those clean welds, good job! gb
01-16-2010, 04:49 PM
Thanks, brother. I try to improve on my welding each time I do it. I guess I'm so used to welding sheetmetal, that it's nice to weld something with some meat behind it every once in a while.
01-16-2010, 04:54 PM
Good deal.
Keep us posted on your build please!
