Old 01-30-2010, 06:32 AM
67bird 67bird is offline
Default 69 Camaro Front Suspension
BAD94,
Not to high jack another guys thread, but the ATS (Speedtech) Chicane brackets are already avalible and have been for some time. You can visit the Speedtech site or the ATS site and find them. If you go to Speedtech first, hit the link for the ATS site. Once there go to products and then suspension. You can find the brackets and the complete Chicane-LM kit. The only differences now are that the kit will most likely be supplied with Speedtech arms, as before they were supplied with GW arms. Also, as mentioned in an earlier post on this thread, they mentioned using QA1 shocks. Before the kits were supplied with either Bilstein or Penske. I would suggest you call Speedtech for more details, but according to the ATS site the brackets were avalible. As far as the kit, I would suppose they could sale you everything in it with exception to the adjustable sway bar (never knew if ATS got it to market) and the spindles, as the are normally on backorder.
Old 01-31-2010, 12:48 PM
Blake Foster's Avatar
we have brackets in stock, we cna set the collars up for QA1 shocks, if your wanting to use any other shock we need to know what ones so we can set up the collars and weld them.
delivery would be a week. depending on what other parts you want.
Blake Foster
www.speedtechperformance.com
