Old 02-11-2010, 01:44 PM
James OLC's Avatar
Default Trailer Hitch Question
I don't know if this is the right forum for this question (so mods please feel free to move it) but...
Does anyone have any suggestions or recommendations for a trailer hitch for a 1967 Camaro?
see... you weren't expecting that question...
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 02-11-2010, 04:15 PM
syborg tt's Avatar
Odd - Actually I was
My Assumption is you want a hitch to pull a small trailer for track stuff
Okay you have a couple options
You can look on ebay and see if you can find the old U-Haul Chain Mount Hitch that they actually made for the camaro's Big and bulky. It basically chains itself to your bumper.
Or Plan B - which i would advise.
Have your local fab shop create a hitch for you. I have one that is already designed for my 2nd gen project. It's pretty simple and almost discreat. Since it have a bent 1/2" plate that will accept the ball.
Take the ball off and all you have is the hitch receiver hanging under the plate. Which means you may have to modify your trailers tounge.
marty-mj
Old 02-11-2010, 04:33 PM
coolwelder62's Avatar
Default 1st.gen hitch
A neat way to build a hitch on a 1st gen would be to use the old rear spring bushing mount bosses for the main surport ,then run some 5/8x2 flat back up along the rear frames rails forward.use a pc.1.5 x.188 sq.tube as cross bar from side to side,then order a 1.25 .id sq.tube recv. order from rigid hitch in minnesota. you can also get saftey chains loops from them to. (www.rigidhitch.comm) call me and I can walk you though it.785-594-7481 Scott Mock.
Old 02-12-2010, 12:39 AM
wellis77's Avatar
wellis77 wellis77 is offline
I'm going to be building a custom for my Dart, and picking up a rear license plate frame off the 77 or so T/A that will hide the receiver. Should work pretty sweet and not be visible when not in use.
Old 02-12-2010, 12:57 AM
KPC67's Avatar
KPC67 KPC67 is offline
James,
maybe you could bring it through the license plate (use a 69 flip down plate)
This way you can hide it, and i bet you could tie it to the frame rails that way.
Kevin Carter
Old 02-12-2010, 12:58 AM
KPC67's Avatar
oops! I guess I should read the whole thing before I put in my two cents.
Kevin Carter
