Old 02-17-2010, 01:56 PM
aussiebj's Avatar
aussiebj aussiebj is offline
2-17-10 updates ...the car has been completely taken back apart to finish all the welding..as well as paint for all the indivdual components..the underside is almost ready for the Lizard skin coating..
Here is the underside before paint
Rear end painted and assembled.
Old 02-17-2010, 01:58 PM
aussiebj's Avatar
I also worked on installing the radiator..i bought the biggest radiator i could get
made fill in pieces to clean up the eng bay
had to go down into the frame and box it up.
Old 02-17-2010, 02:13 PM
70rs's Avatar
70rs 70rs is offline
That is a HUGE radiator!
The project is moving along nice.
Eric
Old 02-17-2010, 07:27 PM
Nice progress. The rear end looks great,and that radiator should keep it cool.
Old 02-22-2010, 02:08 PM
aussiebj's Avatar
2-22-10 finished up majority of the interior metal work then seam sealed it and installed Fat Mat sound deadner....working on finishing up all the under carrige metal work getting ready for the Lizard skin coating..this beast will be quite inside..also started the mock up of the side exhaust..check out the pics..
Fat Matt installed
New style side exhaust..
Old 02-22-2010, 09:23 PM
It looks good, nice progress.
Old 03-07-2010, 05:27 PM
aussiebj's Avatar
3-7-10 finally finished up the welding underneath from the rear crossmember back so i took advantage of the day and sprayed the undercoating ..one container to see what the results were ..Its a product called Raptor Liner...it has the texture im looking for..so ill finish the rear tomorrow..check out the pics.....
Before
After
Before
After
