Old 03-02-2010, 08:05 PM
jmarsa jmarsa is offline
I happened to find mine on craigslist. I've also seen them at my local steel recycling/scrap yard.
--JMarsa
Old 03-02-2010, 09:31 PM
JRouche JRouche is offline
Originally Posted by Garage Dog 65 View Post
Top is here.
1/2 plate with a 5/16th holes grid 4 on 4 center. I have to tap each hole to 3/8 x 16 so I can use all my machinest clamps and 1-2-3 blocks.
That's a lot of holes to tap.... wonder how many beers that will take ...
Jim
I like that plate!!! Gonna make a nice setup plate for whatever comes your way. And tapping the holes is gonna be fun. But a nice new quality tap and some fluid will make it a breeze. Oh, and some tapping fluid might help too JR
Old 03-03-2010, 07:30 AM
GMracer's Avatar
GMracer GMracer is offline
Originally Posted by ironworks View Post
I wish I had your time.
I'm thinking of doing the same thing for my bench, all drilled and tapped so I can make fixtures. Awesome thread
Nick Schiffer
2001 Silverado Regular Cab Short Bed
Currently Under the Knife
Special Thanks to:
Air Ride Technologies - Wilwood Engineering
Old 03-03-2010, 11:22 AM
Originally Posted by mikeb View Post
I was looking for scrap as well, but I don't quite know where to look. The steel plate I have found as scrap has been 1/4 inch. How much does the 32x48 plate weigh?
This thread is great for someone thinking about building a welding table. There are a lot great design features to take.
Hi Mike,
.250 by 32 by 48 steel plate weighs 108.79 lbs.
Here's an online calculator:
http://www.portlandbolt.com/steel-plate-weight.html
Jim
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 03-03-2010, 06:15 PM
mikeb mikeb is offline
Hi Mike,
.250 by 32 by 48 steel plate weights 108.79 lbs.
Jim
I weigh 140 lbs. How do you guys put these tables together?
Old 03-03-2010, 06:28 PM
I must have been 12 the last I weighed that little
My plate is getting moved with my cherry picker.
--JMarsa
Old 03-03-2010, 06:29 PM
I had to build mine upside-down -- on the floor of my shop - then lift it and flip it with my 9000 lb two post lift... and a couple big chains!
A smaller table can be lifted and or moved with an engine hoist... etc.
Old 03-03-2010, 08:02 PM
Default bolting Legs to table top
This might sound dumb, but I'm not an engineer, I just play one at home.
My plate is 4'x6'x1" thick and has 1/2" holes already drilled so I was thinking of caping the legs with a plate and then bolting it to the underside of the top. I like the idea that I can disassemble it and move it if needed. I'll tie the legs toghether too, but my question is is there a need for a base around the perimeter? Any chance this could sag over time given a 5' span between legs?
--JMarsa
Old 03-04-2010, 04:27 PM
ironworks's Avatar
Alright check out what the big boys do.
http://www.race-dezert.com/forum/sho...-Fixture-Table!!!!!!!!
Old 03-04-2010, 05:15 PM
67Sally's Avatar
67Sally 67Sally is online now
I love it when you share
W
William Rouleau
Project PonySnake
