Old 03-21-2010, 09:11 PM
g356gear's Avatar
g356gear g356gear is offline
It's a neat project. My dad still owns a few corvairs that he bought when I was a kid. His first car was a 61 4dr.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 03-22-2010, 06:38 AM
HotRodKush's Avatar
HotRodKush HotRodKush is offline
Originally Posted by monza View Post
A LSX motor is only slightly heavier then a stock Corvair set up. IMO opinion a properly set up LSX powered Corvair would change the entire Corvair after market and make it a viable Hotrod, it would rock.
Not much really to the parts Crown and Kelmark offered, I may still have some of the frame mod parts in my stash if thats the route you want to go?
You might be right about the weight of the LSX motors. I know that there's at least one guy that has done a rear engine LSX swap, but I don't know about the handling of that car. For me though, I've always had this image in my mind of a mid-mounted small block. It's one of those boyhood images that has stuck with me for years, so if for no other reason that's why I'm interested in doing it now.
If you want to sell any of the old parts, I'd be more than interested! I'm more interested in the Crown kits than the Kelmark, if you have any conversion pieces from them
Project "KushVair" - 1967 Corvair Street/Track Build
Old 03-22-2010, 10:51 AM
monza's Avatar
monza monza is offline
I'll look for the parts, that won't be a quick thing but I assume your not in a rush? Totally hear you on boyhood image and the mid mount, I'll not try and talk you out of it, but, have you looked at many up close, have you driven in them? For a full blown beast of a toy it is bad ass! It's also crazy- that engine is in the back seat!!
I have a few pics, specs and basic planning of the LSX in the back I'll forward you that info and contact info of people who have done it. Just think about it....
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
62 Corvair Greenbrier
http://www.sourceboards.com/
Old 03-22-2010, 11:43 AM
HotRodKush's Avatar
Not in a rush at all - I'm thinking that I'll do some sort of V8 project next year sometime, after the rest of the car is all finished. Thanks for the info, I appreciate it - it'll come in handy when the time does come to do something.
Old 03-22-2010, 06:20 PM
byndbad914's Avatar
byndbad914 byndbad914 is offline
that one looks almost in too good of shape to cut up for a V8 conversion That said, go mid-engine mount and use a simple LS1 with 915 Porsche transaxle and you will have a blast of a car... unless you have money to burn then tube chassis the rear with a cage and front tie points, run a hot-rodded LSx with 500+ HP but you have to go 930 trans (which I just sold my old one today) or really expect to pony up the $$ for a Mendy - trust me, I know
I have 525HP when I lived closer to sea level and my 914 is an absolute freakin' rocket and there was a guy with a blown V8 corvair that was rather rough in execution frankly but really pulled out of the corners.
I can tell you the stock chassis of that 'vair is just as wiggly-piggly as my 914 was and out of a corner, on slicks and on throttle I had good grip and power to ground, I could literally feel the chassis wind up on it and that is why I am tube chassis front to rear now. That and the 160+ mph front stretch speeds the car would reach at Willow Springs in SoCal.
This was my car a couple years back
Old 03-27-2010, 10:09 PM
HotRodKush's Avatar
Tim, that's a helluva project!
Took care of the fuel leaks around the carbs today...or at least thought I did. I ordered a set of replacement spacers and base gaskets for both carburetors hoping to fix the big fuel leak I was having on both. The kit came with 2 spacers and upper/lower gaskets for those spacers:
I started by removing both carburetors. As it turns out, ONLY the spacers were present when the carbs came off - no gaskets at all. Ya think that might leak a little?
Then came inspection and cleaning of both mating surfaces of each carb. Here's the bottom of the passenger side carb:
Next, installation of the spacers with one gasket below and one above:
And finally, installed the carburetors:
So, some good and some bad news. The car runs ALOT smoother, which means there was a considerable vacuum leak around those base gaskets before I replaced them. However, it didn't fix the gas leak that I had thought was coming from there. The passenger side is still leaking from somewhere - maybe the float is stuck open? Too much fuel pressure? Other gaskets leaking? I have no idea, I'll have to take another look next week. I'm pleased that the motor is running better though, at least an improvement of some sort occured even though it wasn't the intended one!
Old 03-28-2010, 07:28 AM
monza's Avatar
A bit of a Corvair safety tip. You should ditch that glass fuel filter. IMO not good in any car but, particularly bad in a Corvair with that crazy belt set up and the off chance of flippin' a belt and hitting the glass filter.
Good luck.
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
Old 03-28-2010, 07:44 AM
HotRodKush's Avatar
Thanks, that's a good thought. I'll get a steel cased inline filter on my next parts run.
