Old 03-23-2010, 03:42 PM
Jimi-FM3's Avatar
Jimi-FM3 Jimi-FM3 is offline
Default Cable drive or fly-by-wire
Hey guys, I'd like to get your opinion on whether to install a cable drive or fly-by-wire throttle body and why. My LS3 is shipping without a throttle body and I'd like to make an informed choice on the way to go. Thanks for your input.
Jimi Day
FM3 Performance Marketing, Inc.
http://www.fm3marketing.com
Limitations, like fears, are often imagined...
Old 03-23-2010, 04:04 PM
70rs's Avatar
70rs 70rs is offline
I am glad you posted this question Jimi. I would like to see the responses too.
Eric
Old 03-23-2010, 04:10 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Forgive me for riding on the same coat tail, but I want to know as well. Which is better or the benefits of one over the other?
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 03-23-2010, 04:12 PM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
Hey Jimi, what are you building?
Kurt
Autokraft
Old 03-23-2010, 04:17 PM
ironworks's Avatar
I believe it more depends on the ECU system your using. FAST will be drive by cable. Stock GM ECU for an LS3 with be a drive by wire.
There may be more. But that's what I know. It ain't much but it's something.
I have an Extra Drive by wire throttle body if you need it. And a Drive by cable unit if you want that one also.
Old 03-23-2010, 04:19 PM
Jimi-FM3's Avatar
Sweet, I'm leaning towards the fly-by-wire so put my name on that one unless someone on here convinces me otherwise. I still need the ECU and harness, so I can still go either way.
Jimi Day
Old 03-23-2010, 04:22 PM
Jimi-FM3's Avatar
Kurt
Hey Kurt, I've got an LS3 on the way from Turn Key in Oceanside - it's a crate with a little bit hotter cam and valve springs. I'm putting in my 69 AMX project
https://lateral-g.net/forums/showthread.php4?t=25450
Jimi Day
Old 03-23-2010, 04:31 PM
extralight's Avatar
extralight extralight is offline
I'm interested in everyone's response as well. I'm getting my engine from Regal Performance which has supplied some builds here. Ron there believes that a normal LS engine is fine with drive by wire but one with a hotter cam responds better to cable. He built up a LS3 for his own ride with drive by wire and hated it so much he did switched it out to cable. Given this feedback and his personal experience I opted for cable.
Old 03-23-2010, 05:15 PM
coolwelder62's Avatar
Jimi;Why do you use one of the new Toyota drive by wire TB & gas pedal.
Old 03-23-2010, 05:24 PM
ironworks's Avatar
I hear they're FAST.....
