Old 04-20-2010, 10:03 AM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Originally Posted by War View Post
Looks to me that the floor flexed with the heat. I dont know what size welder your using or how you cooled the weld while you were welding. I would just cut the weld loose, tack the SFC to the subframe, the weld it up.
I'm using a SP-100T Lincoln. I can't see where the heat did this because both sides moved identical, but at this point anything is possible. Plus, I used small stitch welds and moved around enough allowing the welds to cool.
Chris
Old 04-20-2010, 02:10 PM
ItDoRun's Avatar
I talked to Mark at DSE and he pulled Paul in for the discussion. It appears to Paul that the connectors drew upwards from the heat. It doesn't appear to be a problem in terms of function, however he suggested I weld the underside now to help draw it back.
The problem I see is that the connectors are fully welded on the inside of the car and I would think that I need to cut the welds loose to help relieve it so that it would move in the opposite direction.
Maybe I can use something to put tension on it and pull it as it's being welded?????
Any other thoughts?
I see where I messed up now. It's a stupid mistake on my part. I guess i rushed it and didn't stop to think about it drawing as much as it did while welding. What I should have done was welded the some on the top and some on the bottom to minimize the draw. Oh well, lesson learned.
Chris
Old 04-20-2010, 06:32 PM
DRJDVM's '69's Avatar
Personally I think I would just cut the SFC free with a cutoff wheel or air body saw and line them up again and re-weld.... the offset heat thing can get really tricky if you dont know what youre doing....it could even make it worse,or just make a bigger weld that you may end up having to cut free and reposition the pieces anyway.
Heat in sheetmetal can move thing alot....... lesson learned....fix it and move on.
Old 04-20-2010, 07:37 PM
v8s only's Avatar
v8s only v8s only is offline
I got the speed tech body mount bushings, and there is a difference between the firewall one and the rear one. The rear is slightly smaller make sure you didn't mix them up before you welded the frame connectors. Hope this helps!
Tony
68 Camaro pro touring sold
69 Camaro pro touring for sale
62 corvette pro touring sold at barrett jackson
Old 04-20-2010, 09:14 PM
lil427z's Avatar
lil427z lil427z is offline
what you have done is 100% right. go to dse site and take a look at james 69 camaro. hope this helps.
rick k
Old 04-20-2010, 09:44 PM
ItDoRun's Avatar
I should have installed the seat braces first. That would have given the floor pan the additional support it needed during welding.
I'll get it fixed. It's just more time involved and yet another lesson learned.
Chris
