Old 04-20-2010, 06:32 PM
DRJDVM's '69's Avatar
Personally I think I would just cut the SFC free with a cutoff wheel or air body saw and line them up again and re-weld.... the offset heat thing can get really tricky if you dont know what youre doing....it could even make it worse,or just make a bigger weld that you may end up having to cut free and reposition the pieces anyway.
Heat in sheetmetal can move thing alot....... lesson learned....fix it and move on.
Old 04-20-2010, 07:37 PM
v8s only's Avatar
v8s only v8s only is offline
I got the speed tech body mount bushings, and there is a difference between the firewall one and the rear one. The rear is slightly smaller make sure you didn't mix them up before you welded the frame connectors. Hope this helps!
Tony
68 Camaro pro touring sold
69 Camaro pro touring for sale
62 corvette pro touring sold at barrett jackson
Old 04-20-2010, 09:14 PM
lil427z's Avatar
lil427z lil427z is offline
what you have done is 100% right. go to dse site and take a look at james 69 camaro. hope this helps.
rick k
Old 04-20-2010, 09:44 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
I should have installed the seat braces first. That would have given the floor pan the additional support it needed during welding.
I'll get it fixed. It's just more time involved and yet another lesson learned.
Chris
