Old 05-14-2010, 04:28 PM
Ron in SoCal's Avatar
Originally Posted by Ventura View Post
Whats the deal with not using the dropped body bushings? Interference somewhere or?
Two issues I have seen, although some vendors will tell you their product is not affected by half height body bushings (and they could be correct):
1 - Trans tunnel/crossmemeber issue. Using lower height body bushings makes the body sit closer with less space between the frame. You may or may not have this problem, but a larger trans like a t56 may hit the trans tunnel. Ask Todd and Tyler about this one.
2 - Possible inner fender clearance w 275+ tires. Lower body = closer tolerances when suspension compresses.
There's prob more, but that's all I've seen documented. I wanted half height bushings, but a couple of gurus talked me out of it...
Old 05-14-2010, 07:21 PM
awr68's Avatar
awr68 awr68 is offline
Nailed it! Ben there done that! Atleast as far as the T56 goes...I had to raise the trans tunnel .75"
Tony
'68 Camaro
Old 05-14-2010, 07:59 PM
clay69camaro's Avatar
clay69camaro clay69camaro is offline
I'm stickin with the WD subframe.
Undecided on the body mount bushing but thank you everyone for the input. I was actually thinking about the body drop aluminum ones before all this, not anymore though haha.
