Old 05-18-2010, 07:32 PM
BritishGreen68 BritishGreen68 is offline
Default CPP big brake kit, 13" complete kit, first gen camaro or chevelle
I bought a full front and rear brake kit, but I am only going to use the rear kit, so I have this front setup for sale. This is the CPP 13" big brake kit, with billet hubs and the PBR full size truck caliper. The spindles I believe are the GM short spindle for a chevelle,.. here is a link to the kit,
http://www.classicperform.com/NewPro...igBrakeKit.htm
should fit all first gen camaro, and chevelles.. do a little research if your not sure.. The kit is $799 plus shipping from CPP and with no spindles. I am asking $650 shipped for this setup complete......
There are a few things I need that I would possibly trade for-
Nice steering box, and for that matter a good power steering setup
A stainless gas tank (68 camaro)
A kickass shifter for a LT1 T56
An LS1 T56 input shaft
A (preferably wilwood) master cylinder, probably 7/8" bore for manual brakes
Air ride stuff, I need solenoids and a controller, tank, Viair compressor....
Ambition
Chris
Under construction-British Green 68 Camaro-
Old 05-18-2010, 08:34 PM
elitecustombody's Avatar
very interested,is it with dropped spindles?
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 05-18-2010, 08:48 PM
they are not dropped they are OEM...
Chris
Old 05-19-2010, 06:56 AM
can you slide the caliper on the rotor and tell me how what the distance from the top of the caliper to the opposite edge of the rotor ? Trying to find out if they will clear my wheels. Thanks
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 05-19-2010, 01:08 PM
I measured it.. the rotor being 13" exactly, the caliper adds about 1/2" of diameter, or distance from the opposite edge of the rotor 13.5".. The face of the caliper (part you see with the wheel on) is about 1/4" in (towards center of car) from the wheel mounting surface of the rotor. What wheels are you using? I would say this brake setup provides alot of room, with the caliper being "inward" from the wheel mount surface of the rotor it leaves room for wheels that are flat on the back.. these might fit behind a 16" wheel, and 17's should be easy..
Chris
Old 05-19-2010, 01:46 PM
Neil B Neil B is offline
How much does this kit change the track width on a Camaro with OEM front discs?
Old 05-19-2010, 02:08 PM
If I recall it actually pulls the wheels in slightly but I can measure and check that too..
Chris
Old 05-20-2010, 10:28 AM
dsster's Avatar
dsster dsster is offline
16" wheels won't fit to this set up base on my experience. 17" definitely will.
these breaks are actually pretty good for the money. no regrets..
Old 05-20-2010, 11:11 AM
thanks for the info!
Chris
Old 05-20-2010, 12:19 PM
these are on craigslist locally, soon will be on Ebay I was hoping to sell to someone from here but these need to go
Chris
