Old 05-25-2010, 03:37 PM
g356gear's Avatar
g356gear g356gear is offline
Greg,
Did you get yours from Prodigy and the group buy?
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 05-25-2010, 04:02 PM
I tried to do that - and put an order in with Frank - but it was going slowly (for me) and I needed to get one ASAP -- so had to get it from my local parts supplier... I just couldn't wait.
Old 05-28-2010, 07:08 AM
g356gear's Avatar
Pretty sure that GB is dead anyhow. It's been 3 months.
Old 06-02-2010, 06:30 PM
supremeefi supremeefi is offline
Glad to hear about the EZ EFI but in all honesty you're not really comparing apples to apples, you changed the manifold in between.
I'm an Accel dealer and tuner, I did their How To DVD. I've done a bunch of eight stacks and believe me they differ.
Remember these "learning" systems don't have a floor or ceiling meaning they'll keep adding fuel if they detect a lean condition due to an exhaust leak or other. It'll be interesting to see how it actually drives as well.
Old 06-21-2010, 12:01 PM
Hi Greg any updates?
Old 06-21-2010, 01:59 PM
Wayne ---
Running the new EZ EFI on the dyno --- with the new motor - was the best dyno time I've ever had.... WHY?? Because it was so EZ.... which made it F U N !!
Motor and trans are back in the Nomad -- but I've also changed out all the engine wiring - due to the computer change.... and I also have a new radiator and core support from AutoRad. SO there's some work and some changes that are being made other than the EFI.
I just this last week mocked up the core support/radiator... so I can mount P/S reservoir and overflow tanks - check all the fan wiring runs and modify them etc...
Old 06-21-2010, 04:54 PM
Progress is a good thing!!
Old 06-29-2010, 05:18 PM
Revved's Avatar
Revved Revved is offline
We just did our first EZ EFI install here a few weeks back on a 410ci -351W stroker with a DC&O manifold- waiting on finishing up some suspension work on it before putting through major driving but I was amazed how quickly it picked up on self tuning in the limited driving I did. Within about 50 miles it had worked out low to mid throttle accels on 1-4th up to about 65-70 mph and WOT sounded dead crisp the two times I floored it from a stop just to see how it behaved. On first startup it cleaned up the idle within about 2-3 min and starts up every single time with a turn of the key. I'm pretty impressed so far.
We've been using the XFI for the last couple years on a lot of cars but for street driven N/A stuff its overkill. I'm really excited about the EZ EFI for my street driver clients.
-Sean
Comp Performance Group
Business Development Manager
1970 Chevelle I built years back as a Lat-G Feature https://lateral-g.net/forums/showthread.php4?t=43116
Old 06-29-2010, 06:04 PM
Not going to bother with the HASSLE of loading this on Photobucket --- but here's the new 406 (old 427) hanging and ready to slip in... This was a couple of weeks ago but thought I'd post it up anyway.
Old 07-27-2010, 07:42 PM
How's it going Greg? It looks sweet sitting in there.I wish I was closer so I could go see you car in person. I like that sling you have for the engine. I have a load leveler to try on mine when I get it back. Keep us posted on your progress.
